[mapguide-users] download kml and upload kml in fusion
Gordon Luckett gordon.luckett at arrowgeomatics.com
Thu May 19 07:55:12 PDT 2022
What is the URL of the WMS?
On Thu, May 19, 2022 at 10:54 AM Hadis Alinia <hadissaalinia at gmail.com>
wrote:
> component://AddWMSLayer and I can see it in web\www\fusion\widgets folder.
> On Thu, May 19, 2022 at 7:18 AM Gordon Luckett <
> gordon.luckett at arrowgeomatics.com> wrote:
>> Can you send the WMS url you are trying?
>> On Thu., May 19, 2022, 12:52 a.m. Hadis Alinia, <hadissaalinia at gmail.com>
>> wrote:
>>> Thank you Gordon!
>>> I came a cross with Mapguide-react-layout that has the Add/manage layer
>>> component. I know I should add the widget as an invoke URL. In the widgets
>>> I can see see "add WMSlayer" and I tested to add WMS but doesn't work. I am
>>> using mapguide V.3.1.2.9484. I don't see that componnet in my widget list.
>>> Should I do anything to add this widget? Is it the same as openlayers 2.13
>>> that you referenced?
>>> Under option> Editor I see mapguide layout react URL. Is this the one I
>>> need to make a change to? What is that URL?
>>> Thank you
>>> HA
>>> On Wed, May 18, 2022 at 11:48 AM Gordon Luckett <
>>>> Ajax (Basic Web Layout) does not support KML - the Fusion (Flexible Web
>>>> Layout/Web Application) uses OpenLayers 2.13 and this does support KML
>>>> parsing etc.
>>>> On Tue, May 17, 2022 at 7:07 PM Hadis Alinia <hadissaalinia at gmail.com>
>>>> wrote:
>>>>> Hi,
>>>>> I need to enable the user of my webmap application built by Mapguide
>>>>> to overlay their kml layers in ajax view or convert CSVs with lat and lon
>>>>> to a point data and then can download their points data as kml. Or select a
>>>>> feature of the uploaded layer and download it as a kml. Is that even
>>>>> possible in mapguide? I can't find an example searching on google.
>>>>> Please advise
>>>>> Thank you
>>>>> HA
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220519/dd5c8bdc/attachment.htm>
