[mapguide-users] download kml and upload kml in fusion
Hadis Alinia hadissaalinia at gmail.com
Thu May 19 10:03:03 PDT 2022
Sorry I think I am doing something wrong. What URL should I use?
On Thu, May 19, 2022 at 10:55 AM Gordon Luckett <
gordon.luckett at arrowgeomatics.com> wrote:
> What is the URL of the WMS?
> On Thu, May 19, 2022 at 10:54 AM Hadis Alinia <hadissaalinia at gmail.com>
> wrote:
>> component://AddWMSLayer and I can see it in web\www\fusion\widgets
>> folder.
>> On Thu, May 19, 2022 at 7:18 AM Gordon Luckett <
>>> Can you send the WMS url you are trying?
>>> On Thu., May 19, 2022, 12:52 a.m. Hadis Alinia, <hadissaalinia at gmail.com>
>>> wrote:
>>>> Thank you Gordon!
>>>> I came a cross with Mapguide-react-layout that has the Add/manage layer
>>>> component. I know I should add the widget as an invoke URL. In the widgets
>>>> I can see see "add WMSlayer" and I tested to add WMS but doesn't work. I am
>>>> using mapguide V.3.1.2.9484. I don't see that componnet in my widget list.
>>>> Should I do anything to add this widget? Is it the same as openlayers 2.13
>>>> that you referenced?
>>>> Under option> Editor I see mapguide layout react URL. Is this the one I
>>>> need to make a change to? What is that URL?
>>>> Thank you
>>>> HA
>>>> On Wed, May 18, 2022 at 11:48 AM Gordon Luckett <
>>>>> Ajax (Basic Web Layout) does not support KML - the Fusion (Flexible
>>>>> Web Layout/Web Application) uses OpenLayers 2.13 and this does support KML
>>>>> parsing etc.
>>>>> On Tue, May 17, 2022 at 7:07 PM Hadis Alinia <hadissaalinia at gmail.com>
>>>>> wrote:
>>>>>> Hi,
>>>>>> I need to enable the user of my webmap application built by Mapguide
>>>>>> to overlay their kml layers in ajax view or convert CSVs with lat and lon
>>>>>> to a point data and then can download their points data as kml. Or select a
>>>>>> feature of the uploaded layer and download it as a kml. Is that even
>>>>>> possible in mapguide? I can't find an example searching on google.
>>>>>> Please advise
>>>>>> Thank you
>>>>>> HA
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220519/a17e8b74/attachment.htm>
