[mapguide-users] download kml and upload kml in fusion
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Thu May 19 10:05:21 PDT 2022
Which one are you trying?
I usually try one like:
http://wms.ess-ws.nrcan.gc.ca/wms/toporama_en?VERSION=1.1.1&request=GetCapabilities&service=wms
or any one you like...which one are you using?
On Thu, May 19, 2022 at 1:03 PM Hadis Alinia <hadissaalinia at gmail.com>
wrote:
> Sorry I think I am doing something wrong. What URL should I use?
> On Thu, May 19, 2022 at 10:55 AM Gordon Luckett <
> gordon.luckett at arrowgeomatics.com> wrote:
>> What is the URL of the WMS?
>> On Thu, May 19, 2022 at 10:54 AM Hadis Alinia <hadissaalinia at gmail.com>
>> wrote:
>>> component://AddWMSLayer and I can see it in web\www\fusion\widgets
>>> folder.
>>> On Thu, May 19, 2022 at 7:18 AM Gordon Luckett <
>>>> Can you send the WMS url you are trying?
>>>> On Thu., May 19, 2022, 12:52 a.m. Hadis Alinia, <
>>>> hadissaalinia at gmail.com> wrote:
>>>>> Thank you Gordon!
>>>>> I came a cross with Mapguide-react-layout that has the Add/manage
>>>>> layer component. I know I should add the widget as an invoke URL. In the
>>>>> widgets I can see see "add WMSlayer" and I tested to add WMS but doesn't
>>>>> work. I am using mapguide V.3.1.2.9484. I don't see that componnet in my
>>>>> widget list. Should I do anything to add this widget? Is it the same as
>>>>> openlayers 2.13 that you referenced?
>>>>> Under option> Editor I see mapguide layout react URL. Is this the one
>>>>> I need to make a change to? What is that URL?
>>>>> Thank you
>>>>> HA
>>>>> On Wed, May 18, 2022 at 11:48 AM Gordon Luckett <
>>>>>> Ajax (Basic Web Layout) does not support KML - the Fusion (Flexible
>>>>>> Web Layout/Web Application) uses OpenLayers 2.13 and this does support KML
>>>>>> parsing etc.
>>>>>> On Tue, May 17, 2022 at 7:07 PM Hadis Alinia <hadissaalinia at gmail.com>
>>>>>> wrote:
>>>>>>> Hi,
>>>>>>> I need to enable the user of my webmap application built by Mapguide
>>>>>>> to overlay their kml layers in ajax view or convert CSVs with lat and lon
>>>>>>> to a point data and then can download their points data as kml. Or select a
>>>>>>> feature of the uploaded layer and download it as a kml. Is that even
>>>>>>> possible in mapguide? I can't find an example searching on google.
>>>>>>> Please advise
>>>>>>> Thank you
>>>>>>> HA
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220519/40464115/attachment.htm>
