[mapguide-users] download kml and upload kml in fusion
Hadis Alinia hadissaalinia at gmail.com
Thu May 19 10:31:21 PDT 2022
Where should I add this URL? Based on what I've read I need to add
component://AddWMSLayer
to the script to the invoke URL widget:
"<?xml version="1.0"?>
<WidgetType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:type="UiWidgetType">
  <Name>AddWMSLayer</Name>
  <Type>InvokeURL</Type>
  <Location />
  <Extension>
    <Target />
    <Url>Component://AddWMSLayer</Url>
    <DisableIfSelectionEmpty>false</DisableIfSelectionEmpty>
    <AdditionalParameter />
  </Extension>
  <ImageUrl />
  <ImageClass />
  <Label>AddWMSLayer </Label>
  <Tooltip />
  <StatusText />
  <Disabled>false</Disabled>
</WidgetType>"
Where should I add that URL address?
On Thu, May 19, 2022 at 1:05 PM Gordon Luckett <
gordon.luckett at arrowgeomatics.com> wrote:
> Which one are you trying?
> I usually try one like:
> http://wms.ess-ws.nrcan.gc.ca/wms/toporama_en?VERSION=1.1.1&request=GetCapabilities&service=wms
> or any one you like...which one are you using?
> On Thu, May 19, 2022 at 1:03 PM Hadis Alinia <hadissaalinia at gmail.com>
> wrote:
>> Sorry I think I am doing something wrong. What URL should I use?
>> On Thu, May 19, 2022 at 10:55 AM Gordon Luckett <
>>> What is the URL of the WMS?
>>> On Thu, May 19, 2022 at 10:54 AM Hadis Alinia <hadissaalinia at gmail.com>
>>> wrote:
>>>> component://AddWMSLayer and I can see it in web\www\fusion\widgets
>>>> folder.
>>>> On Thu, May 19, 2022 at 7:18 AM Gordon Luckett <
>>>>> Can you send the WMS url you are trying?
>>>>> On Thu., May 19, 2022, 12:52 a.m. Hadis Alinia, <
>>>>> hadissaalinia at gmail.com> wrote:
>>>>>> Thank you Gordon!
>>>>>> I came a cross with Mapguide-react-layout that has the Add/manage
>>>>>> layer component. I know I should add the widget as an invoke URL. In the
>>>>>> widgets I can see see "add WMSlayer" and I tested to add WMS but doesn't
>>>>>> work. I am using mapguide V.3.1.2.9484. I don't see that componnet in my
>>>>>> widget list. Should I do anything to add this widget? Is it the same as
>>>>>> openlayers 2.13 that you referenced?
>>>>>> Under option> Editor I see mapguide layout react URL. Is this the one
>>>>>> I need to make a change to? What is that URL?
>>>>>> Thank you
>>>>>> HA
>>>>>> On Wed, May 18, 2022 at 11:48 AM Gordon Luckett <
>>>>>>> Ajax (Basic Web Layout) does not support KML - the Fusion (Flexible
>>>>>>> Web Layout/Web Application) uses OpenLayers 2.13 and this does support KML
>>>>>>> parsing etc.
>>>>>>> On Tue, May 17, 2022 at 7:07 PM Hadis Alinia <
>>>>>>>> Hi,
>>>>>>>> I need to enable the user of my webmap application built by
>>>>>>>> Mapguide to overlay their kml layers in ajax view or convert CSVs with lat
>>>>>>>> and lon to a point data and then can download their points data as kml. Or
>>>>>>>> select a feature of the uploaded layer and download it as a kml. Is that
>>>>>>>> even possible in mapguide? I can't find an example searching on google.
>>>>>>>> Please advise
>>>>>>>> Thank you
>>>>>>>> HA
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220519/ab1b3b9f/attachment.htm>
