[mapguide-users] HTTP with MGOS3.1
pierre.cardinal at sympatico.ca
Sat May 28 06:01:50 PDT 2022
Solution: In the «manual » installation process, it is necessary to add the
handler isapi_MapAgent.dll for mapagent.fcgi in the mapagent
application
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de
Envoyé : 27 mai 2022 15:59
À : mapguide-users at lists.osgeo.org
Objet : [mapguide-users] HTTP with MGOS3.1
Build 3.1.0, PHP php-5.6.40-Win32-VC11-x64, IIS
Server installation with .\build64.bat -o=d:\mgos31 -a=install -w=server
MgServer is running.
Web installation with .\build64.bat -o=d:\mgos31 -a=install -w=web
I am using FastCGI for the PHP requests with php-cgi.exe.
MapGuide Extensions enabled in php.ini.
PHP Is responding well, mapadmin is ok, but
http://localhost/mapguide/mapagent/mapagent.fcgi
<http://localhost/mapguide/mapagent/mapagent.fcgi%20prod> produces a 404.3
error. The problem is with the StaticFileModule
(ex. In Coordinate System : GetBaseLibrary with HTTP is not OK, but
GetBaseLibrary with PHP is OK)
Any idea in the room ?
Pierre
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220528/aa0a8ac5/attachment.htm>
