[mapguide-users] HTTP with MGOS3.1
Gordon Luckett gordon.luckett at arrowgeomatics.com
Sat May 28 06:04:27 PDT 2022
You may have to add another too.
Check out this older page:
https://trac.osgeo.org/mapguide/wiki/ConfigureGuide24Windows
On Sat., May 28, 2022, 9:01 a.m. , <pierre.cardinal at sympatico.ca> wrote:
> Solution: In the «manual » installation  process, it is necessary to add
> the handler “isapi_MapAgent.dll”  for “mapagent.fcgi” in the mapagent
> application
> *De :* mapguide-users <mapguide-users-bounces at lists.osgeo.org> *De la
> part de* pierre.cardinal at sympatico.ca
> *Envoyé :* 27 mai 2022 15:59
> *À :* mapguide-users at lists.osgeo.org
> *Objet :* [mapguide-users] HTTP with MGOS3.1
> Hi,
> Build 3.1.0, PHP php-5.6.40-Win32-VC11-x64, IIS
> Server installation with .\build64.bat -o=d:\mgos31 -a=install -w=server
> MgServer is running.
> Web installation with .\build64.bat -o=d:\mgos31 -a=install -w=web
> I am using FastCGI for the PHP requests with php-cgi.exe.
> MapGuide Extensions enabled in php.ini.
> PHP Is responding well,  mapadmin is ok, but  http://localhost/mapguide/mapagent/mapagent.fcgi
> <http://localhost/mapguide/mapagent/mapagent.fcgi%20prod> produces a
> 404.3  error. The problem is with the StaticFileModule
> (ex. In Coordinate System : GetBaseLibrary with HTTP is not OK, but
> GetBaseLibrary with PHP is OK)
> Any idea in the room ?
> Pierre
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220528/560b2b1c/attachment.htm>
