[mapguide-users] HTTP with MGOS3.1
Jackie Ng
jumpinjackie at gmail.com
Tue May 31 02:38:37 PDT 2022
Rather than manually configuring your freshly built MapGuide installation,
consider using the MgInstantSetup utility to do all the required
configuration automatically for you. This tool is bundled with the
instantsetup package of every MapGuide release that provides said packages.
- Jackie
You wrote:
Solution: In the «manual » installation process, it is necessary to add the
handler “isapi_MapAgent.dll” for “mapagent.fcgi” in the mapagent
application
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220531/447fe5c9/attachment.htm>
