[mapguide-users] fusion error in google chrome
Hadis Alinia
hadissaalinia at gmail.com
Wed Oct 5 14:23:12 PDT 2022
Hi Gordon,
Thank you for your prompt reply. Can you specify where I need to change the
links to the xyz version? I am adding the commercial maps in Mapguide
Maestro under child maps with the google API I have.
I have the following scripts in my application definition XML :
" <OpenStreetMapScript>
http://www.openstreetmap.org/openlayers/OpenStreetMap.js
</OpenStreetMapScript>
<GoogleScript>https://maps.googleapis.com/maps/api/js?key=API
KEY</GoogleScript>"
or do you mean I change the http://www.google.com links
in fusionSF-compressed.js to
https://mt0.google.com/vt/lyrs=m&hl=en&x=${x}&y=${y}&z=${z}?
Thank you
Hadis
On Wed, Oct 5, 2022 at 3:19 PM Gordon Luckett <
gordon.luckett at arrowgeomatics.com> wrote:
> Something has recently changed in the past month or so with the Google API.
> I have changed all my links to Google to use the XYZ version:
> You should still have an API Key (or at least pay for the licence) as it
> is required by the TOS
> On Wed, Oct 5, 2022 at 2:04 PM Hadis Alinia <hadissaalinia at gmail.com>
> wrote:
>> Hi,
>> I am using MapGuide version 3.1.2 and when I add the commercial layers my
>> application doesn't open in google chrome but works fine with other
>> browsers like Microsoft Edge. When I try to open it in Google Chrome, I get
>> the following errors "Cannot read properties of undefined (reading
>> 'width')
>> Stack Trace:
>> - ? at /mapguide/fusion/lib/fusionSF-compressed.js (line: 57)
>> - ? at https://maps.googleapis.com/maps-api-v3/api/js/50/7a/util.js (line: 328)
>> - ? at https://maps.googleapis.com/maps-api-v3/api/js/50/7a/util.js (line: 21)
>> - ? at /mapguide/fusion/lib/fusionSF-compressed.js (line: 55)"
>> I even changed fusionSF-compressed.js to fusionSF.js still doesn't work.
>> The MapGuide version 2 was working with commercial layers.
>> What is the reason and what changes need to be made?
>> Thank you
>> Hadis
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20221005/683efe1f/attachment.htm>
