[mapguide-users] fusion error in google chrome
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Wed Oct 5 14:26:31 PDT 2022
It is just a XYZ Generic Layer in your layout.
[image: image.png]
On Wed, Oct 5, 2022 at 5:23 PM Hadis Alinia <hadissaalinia at gmail.com> wrote:
> Hi Gordon,
> Thank you for your prompt reply. Can you specify where I need to change
> the links to the xyz version? I am adding the commercial maps in Mapguide
> Maestro under child maps with the google API I have.
> I have the following scripts in my application definition XML :
> " <OpenStreetMapScript>
> http://www.openstreetmap.org/openlayers/OpenStreetMap.js
> </OpenStreetMapScript>
> <GoogleScript>https://maps.googleapis.com/maps/api/js?key=API
> KEY</GoogleScript>"
> or do you mean I change the http://www.google.com links
> in fusionSF-compressed.js to
> https://mt0.google.com/vt/lyrs=m&hl=en&x=${x}&y=${y}&z=${z}?
> Thank you
> Hadis
> On Wed, Oct 5, 2022 at 3:19 PM Gordon Luckett <
> gordon.luckett at arrowgeomatics.com> wrote:
>> Something has recently changed in the past month or so with the Google
>> API.
>> I have changed all my links to Google to use the XYZ version:
>> You should still have an API Key (or at least pay for the licence) as it
>> is required by the TOS
>> On Wed, Oct 5, 2022 at 2:04 PM Hadis Alinia <hadissaalinia at gmail.com>
>> wrote:
>>> Hi,
>>> I am using MapGuide version 3.1.2 and when I add the commercial layers
>>> my application doesn't open in google chrome but works fine with other
>>> browsers like Microsoft Edge. When I try to open it in Google Chrome, I get
>>> the following errors "Cannot read properties of undefined (reading
>>> 'width')
>>> Stack Trace:
>>> - ? at /mapguide/fusion/lib/fusionSF-compressed.js (line: 57)
>>> - ? at https://maps.googleapis.com/maps-api-v3/api/js/50/7a/util.js (line: 328)
>>> - ? at https://maps.googleapis.com/maps-api-v3/api/js/50/7a/util.js (line: 21)
>>> - ? at /mapguide/fusion/lib/fusionSF-compressed.js (line: 55)"
>>> I even changed fusionSF-compressed.js to fusionSF.js still doesn't work.
>>> The MapGuide version 2 was working with commercial layers.
>>> What is the reason and what changes need to be made?
>>> Thank you
>>> Hadis
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20221005/880220ee/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20221005/880220ee/attachment.png>
