[mapguide-users] fusion error in google chrome
Hadis Alinia
hadissaalinia at gmail.com
Wed Oct 5 19:13:14 PDT 2022
Thank you, Gordon. The site loads in Google Chrome with the Generic XYZ
layer but with adding any of the Google Base maps I get the same error!
I need to use google street view and it doesn't work without the google
base map.
Hadis
On Wed, Oct 5, 2022 at 5:27 PM Gordon Luckett <
gordon.luckett at arrowgeomatics.com> wrote:
> It is just a XYZ Generic Layer in your layout.
> [image: image.png]
> On Wed, Oct 5, 2022 at 5:23 PM Hadis Alinia <hadissaalinia at gmail.com>
> wrote:
>> Hi Gordon,
>> Thank you for your prompt reply. Can you specify where I need to change
>> the links to the xyz version? I am adding the commercial maps in Mapguide
>> Maestro under child maps with the google API I have.
>> I have the following scripts in my application definition XML :
>> " <OpenStreetMapScript>
>> http://www.openstreetmap.org/openlayers/OpenStreetMap.js
>> </OpenStreetMapScript>
>> <GoogleScript>https://maps.googleapis.com/maps/api/js?key=API
>> KEY</GoogleScript>"
>> or do you mean I change the http://www.google.com links
>> in fusionSF-compressed.js to
>> https://mt0.google.com/vt/lyrs=m&hl=en&x=${x}&y=${y}&z=${z}?
>> Thank you
>> Hadis
>> On Wed, Oct 5, 2022 at 3:19 PM Gordon Luckett <
>>> Something has recently changed in the past month or so with the Google
>>> API.
>>> I have changed all my links to Google to use the XYZ version:
>>> You should still have an API Key (or at least pay for the licence) as it
>>> is required by the TOS
>>> On Wed, Oct 5, 2022 at 2:04 PM Hadis Alinia <hadissaalinia at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I am using MapGuide version 3.1.2 and when I add the commercial layers
>>>> my application doesn't open in google chrome but works fine with other
>>>> browsers like Microsoft Edge. When I try to open it in Google Chrome, I get
>>>> the following errors "Cannot read properties of undefined (reading
>>>> 'width')
>>>> Stack Trace:
>>>> - ? at /mapguide/fusion/lib/fusionSF-compressed.js (line: 57)
>>>> - ? at https://maps.googleapis.com/maps-api-v3/api/js/50/7a/util.js (line: 328)
>>>> - ? at https://maps.googleapis.com/maps-api-v3/api/js/50/7a/util.js (line: 21)
>>>> - ? at /mapguide/fusion/lib/fusionSF-compressed.js (line: 55)"
>>>> I even changed fusionSF-compressed.js to fusionSF.js still doesn't
>>>> work.
>>>> The MapGuide version 2 was working with commercial layers.
>>>> What is the reason and what changes need to be made?
>>>> Thank you
>>>> Hadis
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20221005/ae7791c7/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20221005/ae7791c7/attachment.png>
