[mapguide-users] Migrating Mapguide 2.4 from Server2012 to 2019
pierre.cardinal at sympatico.ca
Thu Sep 8 13:28:56 PDT 2022
Why dont you try MGOS 3.1.2 ?
Pierre
-----Message d'origine-----
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de mg at maw-gis.de
Envoyé : 8 septembre 2022 09:36
À : mapguide-users at lists.osgeo.org
Objet : Re: [mapguide-users] Migrating Mapguide 2.4 from Server2012 to 2019
No sorry,
this was the first thing I tried.
Am 08.09.2022 um 15:16 schrieb pierre.cardinal at sympatico.ca:
> Hi,
> Perhaps this one
> https://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg23472.h
> tml
> Regards,
> Pierre
> part de mg at maw-gis.de Envoyé : 8 septembre 2022 02:11 À :
> mapguide-users at lists.osgeo.org Objet : Re: [mapguide-users] Migrating
> Hi,
> I did read this before, but it doesn't help. The Layers were not selectable.
> Any other ideas ?
> Regards
> Uwe
> Am 07.09.2022 um 15:47 schrieb pierre.cardinal at sympatico.ca:
>> Hi,
>> Give a look at
>> https://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg20022.
>> h
>> tml
>> (4 messages)
>> Regards,
>> Pierre
>> part de mg at maw-gis.de Envoyé : 7 septembre 2022 05:05 À :
>> mapguide-users at lists.osgeo.org Objet : [mapguide-users] Migrating
>> Hi,
>> I installed exactly the same version of Mapguide on the new server,
>> the data was transferred unchanged.
>> There are problems with TIF images that are integrated using GDAL
>> Feature Source. This errors are in the log file:
>> 2022-09-07T10:44:48> 3876 MapGuide Maestro v6.0.0.8244
>> 192.168.5.181 Administrator
>> Error: An exception occurred in FDO component.
>> Error occurred in Feature Source
>> (Library://Feucht/Data/Topologie/DOK.FeatureSource): Only MOSAIC(),
>> CLIP() and RESAMPLE() are supported. (Cause: , Root Cause: Only
>> MOSAIC(), CLIP() and
>> RESAMPLE() are supported.)
>> StackTrace:
>> - MgFeatureServiceHandler.ProcessOperation() line 83 file
>> c:\mg-2.4-x86\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>> - MgOpSelectFeaturesSpatial.Execute() line 110 file
>> c:\mg-2.4-x86\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>> - MgServerFeatureService.SelectAggregate() line 570 file
>> c:\mg-2.4-x86\mgdev\server\src\services\feature\ServerFeatureService.cpp
>> - MgServerSelectFeatures.SelectFeatures() line 325 file
>> c:\mg-2.4-x86\mgdev\server\src\services\feature\ServerSelectFeatures.
>> c
>> pp
>> <2022-09-07T10:46:50> 1424 Fusion Viewer 192.168.5.68 xxx
>> Error: Failed to stylize layer: DOK
>> (Library://Feucht/Data/Topologie/DOK.FeatureSource): Fail to get
>> image information. (Cause: , Root Cause: Fail to get image information.)
>> StackTrace:
>> - MgMappingUtil.StylizeLayers() line 881 file
>> c:\mg-2.4-x86\mgdev\server\src\services\mapping\MappingUtil.cpp
>> Does anyone have an idea what is going wrong here?
>> mapguide-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
