[mapguide-users] Migrating Mapguide 2.4 from Server2012 to 2019
mg at maw-gis.de mg at maw-gis.de
Thu Sep 8 23:59:54 PDT 2022
we have developed a special frontend based on fusion. It takes a lot of work to adapt them (and
nobody would pay for it). All other 90 layers work perfectly, only the layers with tiffs cause
problems. Something must have changed somewhere in the depths of Server 2019...
Am 08.09.2022 um 22:28 schrieb pierre.cardinal at sympatico.ca:
> Hi,
> Why dont you try MGOS 3.1.2 ?
> Pierre
> -----Message d'origine-----
> De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de mg at maw-gis.de
> Envoyé : 8 septembre 2022 09:36
> À : mapguide-users at lists.osgeo.org
> Objet : Re: [mapguide-users] Migrating Mapguide 2.4 from Server2012 to 2019
> No sorry,
> this was the first thing I tried.
> Am 08.09.2022 um 15:16 schrieb pierre.cardinal at sympatico.ca:
>> Hi,
>> Perhaps this one
>> https://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg23472.h
>> tml
>> Regards,
>> Pierre
>> part de mg at maw-gis.de Envoyé : 8 septembre 2022 02:11 À :
>> mapguide-users at lists.osgeo.org Objet : Re: [mapguide-users] Migrating
>> Hi,
>>     I did read this before, but it doesn't help. The Layers were not selectable.
>> Any other ideas ?
>> Regards
>>     Uwe
>> Am 07.09.2022 um 15:47 schrieb pierre.cardinal at sympatico.ca:
>>> Hi,
>>> Give a look  at
>>> https://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg20022.
>>> h
>>> tml
>>> (4 messages)
>>> Regards,
>>> Pierre
>>> part de mg at maw-gis.de Envoyé : 7 septembre 2022 05:05 À :
>>> mapguide-users at lists.osgeo.org Objet : [mapguide-users] Migrating
>>> Hi,
>>> I installed exactly the same version of Mapguide on the new server,
>>> the data was transferred unchanged.
>>> There are problems with TIF images that are integrated using GDAL
>>> Feature Source. This errors are in the log file:
>>> 2022-09-07T10:44:48> 	3876	MapGuide Maestro v6.0.0.8244
>>> 192.168.5.181	Administrator
>>>      Error: An exception occurred in FDO component.
>>>             Error occurred in Feature Source
>>> (Library://Feucht/Data/Topologie/DOK.FeatureSource): Only MOSAIC(),
>>> CLIP() and RESAMPLE() are supported. (Cause: , Root Cause: Only
>>> MOSAIC(), CLIP() and
>>> RESAMPLE() are supported.)
>>>      StackTrace:
>>>       - MgFeatureServiceHandler.ProcessOperation() line 83 file
>>> c:\mg-2.4-x86\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>>>       - MgOpSelectFeaturesSpatial.Execute() line 110 file
>>> c:\mg-2.4-x86\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>>>       - MgServerFeatureService.SelectAggregate() line 570 file
>>> c:\mg-2.4-x86\mgdev\server\src\services\feature\ServerFeatureService.cpp
>>>       - MgServerSelectFeatures.SelectFeatures() line 325 file
>>> c:\mg-2.4-x86\mgdev\server\src\services\feature\ServerSelectFeatures.
>>> c
>>> pp
>>> <2022-09-07T10:46:50> 	1424	Fusion Viewer	192.168.5.68	xxx
>>>      Error: Failed to stylize layer: DOK
>>> (Library://Feucht/Data/Topologie/DOK.FeatureSource): Fail to get
>>> image information. (Cause: , Root Cause: Fail to get image information.)
>>>      StackTrace:
>>>       - MgMappingUtil.StylizeLayers() line 881 file
>>> c:\mg-2.4-x86\mgdev\server\src\services\mapping\MappingUtil.cpp
>>> Does anyone have an idea what is going wrong here?
>>> mapguide-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
