[mapguide-users] React layout warning: Could not find the context menu configuration
Kajar Kuldsepp kajar.kuldsepp at gmail.com
Thu Sep 15 01:38:06 PDT 2022
Hi!
I'm experience warning when using React layout. It happens when I start
using latest 0.14.7 version.
During load I will get warning:
The following warnings were encountered loading the viewer
   - Could not find the context menu configuration. Right-clicking the map
   will show an empty context menu. If you are loading from a Flexible Layout,
   it must have a container named 'MapContextMenu'
It happens all flexible layouts I have created and also all react templates.
I also did one test and created layout without  MaprightclickMenu widget,
but still same warning on load. Does anyone else have experienced same
problem and how to get rid of it?
Kajar
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220915/c3fe8d38/attachment.htm>
