[mapguide-users] React layout warning: Could not find the context menu configuration
Kajar Kuldsepp kajar.kuldsepp at gmail.com
Thu Sep 15 23:39:39 PDT 2022
Thank you!
I just needed to replace container MapRightclickMenu to MapContextMenu
and now its working.
Hi  Kajar,
In your ApplicationDefiniton resource, do you have a Container with the name
MapContextMenu ?
   <Container xsi:type="UiItemContainerType">
      <Name>MapContextMenu</Name>
      <Type>ContextMenu</Type>
      <Position>top</Position>
      <Extension />
      <Item xsi:type="WidgetItemType">  etc
(look at the attached file)
The warning is displayed when the Container is missing from the resource. In
Maestro you can edit the resource by opening  your Flexible Layout and click on
the menu [Edit as XML] at the top.
Regards,
Pierre
De : mapguide-users <mapguide-users-boun... at lists.osgeo.org> De la part de
Kajar Kuldsepp
Envoyé : 15 septembre 2022 04:38
À : mapguide-users at lists.osgeo.org
Objet : [mapguide-users] React layout warning: Could not find the context menu
configuration
Hi!
I'm experience warning when using React layout. It happens when I start using
latest 0.14.7 version.
During load I will get warning:
The following warnings were encountered loading the viewer
*       Could not find the context menu configuration. Right-clicking the map
will show an empty context menu. If you are loading from a Flexible Layout, it
must have a container named 'MapContextMenu'
It happens all flexible layouts I have created and also all react templates.
I also did one test and created layout without  MaprightclickMenu widget, but
still same warning on load. Does anyone else have experienced same problem and
how to get rid of it?
Kajar
<?xml version="1.0" encoding="utf-8"?>
<ApplicationDefinition
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance";
xmlns:xsd="http://www.w3.org/2001/XMLSchema";
xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
  <Title>Slate</Title>
  <TemplateUrl>fusion/templates/mapguide/slate/index.html</TemplateUrl>
  <MapSet>
    <MapGroup id="MainMap">
      <Map>
        <Type>MapGuide</Type>
        <SingleTile>True</SingleTile>
        <Extension>
          <ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</ResourceId>
          <Options>
            <isBaseLayer>false</isBaseLayer>
            <useOverlay>true</useOverlay>
            <projection>EPSG:900913</projection>
          </Options>
        </Extension>
      </Map>
    </MapGroup>
  </MapSet>
  <WidgetSet>
      <Name>Toolbar</Name>
      <Type>Toolbar</Type>
      <Extension />
        <Function>Widget</Function>
        <Widget>CoordinateTracker</Widget>
      </Item>
        <Widget>demoComponentTest</Widget>
      </Item>
        <Widget>messageComponent</Widget>
      </Item>
        <Widget>ViewAsKml</Widget>
      </Item>
        <Widget>QuickPlot</Widget>
      </Item>
      <Item xsi:type="SeparatorItemType">
        <Function>Separator</Function>
      </Item>
        <Widget>RefreshMap</Widget>
      </Item>
        <Widget>Maptip</Widget>
      </Item>
        <Widget>SelectRadius</Widget>
      </Item>
        <Widget>SelectPolygon</Widget>
      </Item>
        <Widget>ClearSelection</Widget>
      </Item>
        <Widget>tbBuffer</Widget>
      </Item>
        <Widget>Measure</Widget>
      </Item>
        <Widget>FeatureInfo</Widget>
      </Item>
        <Widget>Query</Widget>
      </Item>
        <Widget>Theme</Widget>
      </Item>
        <Widget>Redline</Widget>
      </Item>
        <Widget>ViewOptions</Widget>
      </Item>
        <Widget>About</Widget>
      </Item>
        <Widget>Help</Widget>
      </Item>
    </Container>
      <Name>ToolbarSecondary</Name>
      <Extension />
        <Widget>Select</Widget>
      </Item>
        <Widget>Pan</Widget>
      </Item>
        <Widget>Zoom</Widget>
      </Item>
        <Widget>ZoomIn</Widget>
      </Item>
        <Widget>ZoomOut</Widget>
      </Item>
        <Widget>InitialMapView</Widget>
      </Item>
        <Widget>ZoomToSelection</Widget>
      </Item>
        <Widget>PreviousView</Widget>
      </Item>
        <Widget>NextView</Widget>
      </Item>
    </Container>
      <Name>ToolbarVertical</Name>
      <Position>left</Position>
      <Extension />
        <Widget>vertSelect</Widget>
      </Item>
        <Widget>vertPan</Widget>
      </Item>
        <Widget>vertZoom</Widget>
      </Item>
        <Widget>vertZoomIn</Widget>
      </Item>
        <Widget>vertZoomOut</Widget>
      </Item>
        <Widget>vertInitialMapView</Widget>
      </Item>
        <Widget>vertZoomToSelection</Widget>
      </Item>
        <Widget>vertPreviousView</Widget>
      </Item>
        <Widget>vertNextView</Widget>
      </Item>
    </Container>
      <Name>FileMenu</Name>
      <Extension />
        <Widget>MapMenu</Widget>
      </Item>
        <Widget>BasemapSwitcher</Widget>
      </Item>
      <Item xsi:type="FlyoutItemType">
        <Function>Flyout</Function>
        <Label>View</Label>
          <Widget>showOverview</Widget>
        </Item>
          <Widget>showTaskPane</Widget>
        </Item>
          <Widget>showLegend</Widget>
        </Item>
          <Widget>showSelectionPanel</Widget>
        </Item>
      </Item>
    </Container>
      <Name>Statusbar</Name>
      <Type>Splitterbar</Type>
      <Position>bottom</Position>
      <Extension />
        <Widget>statusCoordinates</Widget>
      </Item>
        <Widget>statusSelection</Widget>
      </Item>
        <Widget>EditableScale</Widget>
      </Item>
        <Widget>statusViewSize</Widget>
      </Item>
    </Container>
      <Name>xMapContextMenu</Name>
      <Extension />
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
        <Label>Zoom</Label>
      </Item>
      </Item>
      </Item>
      </Item>
        <Label>Select More</Label>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
    </Container>
      <Name>TaskMenu</Name>
      <Extension />
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
      </Item>
    </Container>
    <MapWidget>
      <Name>Map</Name>
      <Type>Map</Type>
      <Extension>
        <MenuContainer>MapContextMenu</MenuContainer>
      </Extension>
      <MapId>MainMap</MapId>
    </MapWidget>
    <Widget xsi:type="UiWidgetType">
      <Name>About</Name>
      <Type>About</Type>
      <Location />
      <Extension>
        <AboutURL>widgets/About/About.html</AboutURL>
      </Extension>
      <ImageUrl>images/icons.png</ImageUrl>
      <ImageClass>about</ImageClass>
      <Label>About</Label>
      <Tooltip>Click to show information about this application</Tooltip>
      <StatusText />
      <Disabled>false</Disabled>
    </Widget>
    <Widget>
      <Name>ActivityIndicator</Name>
      <Type>ActivityIndicator</Type>
      <Location />
      <Extension>
        <ElementId>
        </ElementId>
      </Extension>
    </Widget>
      <Name>BasemapSwitcher</Name>
      <Type>BasemapSwitcher</Type>
      <Location />
      <Extension />
      <ImageClass>options</ImageClass>
      <Label>External Providers</Label>
      <Tooltip>Click to change the basemap</Tooltip>
      <StatusText />
    </Widget>
      <Name>BufferPanel</Name>
      <Type>BufferPanel</Type>
      <Location />
      <Extension>
        <Target>TaskPane</Target>
      </Extension>
      <ImageClass>buffer</ImageClass>
      <Label>Buffer</Label>
      <Tooltip>Click to create a buffer</Tooltip>
      <StatusText />
    </Widget>
      <Name>CenterSelection</Name>
      <Type>CenterSelection</Type>
      <Location />
      <Extension />
      <ImageClass>select-centre</ImageClass>
      <Label>Center selection</Label>
      <Tooltip>Click to center the map on the current selection</Tooltip>
      <StatusText />
    </Widget>
      <Name>ClearSelection</Name>
      <Type>ClearSelection</Type>
      <Location />
      <Extension />
      <ImageClass>select-clear</ImageClass>
      <Label>Clear Selection</Label>
      <Tooltip>Click to clear the current selection</Tooltip>
      <StatusText />
    </Widget>
      <Name>ColorPicker</Name>
      <Type>ColorPicker</Type>
      <Location />
      <Extension>
        <ColorInputId>
        </ColorInputId>
      </Extension>
      <ImageUrl />
      <ImageClass />
      <Label>Color picker</Label>
      <Tooltip>Use this tool to select a color</Tooltip>
      <StatusText />
    </Widget>
      <Name>CoordinateTracker</Name>
      <Type>CoordinateTracker</Type>
      <Location />
      <Extension>
        <Projection>EPSG:3857</Projection>
      </Extension>
      <ImageClass>coordinate-tracker</ImageClass>
      <Label>Coordinate Tracker</Label>
      <Tooltip>Click to view mouse coordinates in various projections</Tooltip>
      <StatusText />
    </Widget>
    <Widget>
      <Name>EditableScale</Name>
      <Type>EditableScale</Type>
      <Location />
      <Extension>
        <Precision>4</Precision>
      </Extension>
    </Widget>
      <Name>FeatureInfo</Name>
      <Type>FeatureInfo</Type>
      <Location />
      <Extension>
      </Extension>
      <ImageClass>feature-info</ImageClass>
      <Label>Feature Info</Label>
      <Tooltip>Click to display selected feature info</Tooltip>
      <StatusText />
    </Widget>
      <Name>Geolocation</Name>
      <Type>Geolocation</Type>
      <Location />
      <Extension>
        <ZoomLevel>
        </ZoomLevel>
        <EnableHighAccuracy>false</EnableHighAccuracy>
        <Timeout>5000</Timeout>
        <MaximumAge>0</MaximumAge>
      </Extension>
      <ImageClass>geolocation</ImageClass>
      <Label>My Location</Label>
      <Tooltip>Click to zoom to your current geographic location</Tooltip>
      <StatusText />
    </Widget>
      <Name>GoogleStreetViewer</Name>
      <Type>GoogleStreetViewer</Type>
      <Location />
      <Extension>
        <SymbolLayerName>GoogleStreetViewerSymbolLayer</SymbolLayerName>
        <ShowDirection>true</ShowDirection>
        <DirectionLength>22</DirectionLength>
        <AdditionalParameter>
        </AdditionalParameter>
      </Extension>
      <ImageUrl>../../../widgets/GoogleStreetViewer/GoogleStreetView.png</ImageUrl>
      <ImageClass />
      <Label>Google StreetView</Label>
      <Tooltip>Click to show Google StreetView</Tooltip>
      <StatusText />
    </Widget>
      <Name>Help</Name>
      <Type>Help</Type>
      <Location />
      <Extension>
        <Target>HelpWindow</Target>
        <Url>widgets/Help/Help.html</Url>
      </Extension>
      <ImageClass>help</ImageClass>
      <Label>Help</Label>
      <Tooltip>Click to get help</Tooltip>
      <StatusText />
    </Widget>
      <Name>InitialMapView</Name>
      <Type>InitialMapView</Type>
      <Location />
      <Extension>
        <ViewType>initial</ViewType>
      </Extension>
      <ImageClass>zoom-full</ImageClass>
      <Label>Zoom Extents</Label>
      <Tooltip>Click to zoom to the full map extents</Tooltip>
      <StatusText />
    </Widget>
    <Widget>
      <Name>Legend</Name>
      <Type>Legend</Type>
      <Location />
      <Extension>
        <HideInvisibleLayers>true</HideInvisibleLayers>
        <ShowRootFolder>false</ShowRootFolder>
        <ShowMapFolder>false</ShowMapFolder>
        <LayerRasterIcon>images/icons/legend-raster.png</LayerRasterIcon>
        <LayerDWFIcon>images/icons/legend-DWF.png</LayerDWFIcon>
        <LayerThemeIcon>images/icons/legend-theme.png</LayerThemeIcon>
        <DisabledLayerIcon>images/icons/legend-layer.png</DisabledLayerIcon>
        <LayerInfoIcon>images/icons/tree_layer_info.png</LayerInfoIcon>
        <GroupInfoIcon>images/icons/tree_group_info.png</GroupInfoIcon>
        <RootFolderIcon>images/icons/legend-map.png</RootFolderIcon>
      </Extension>
    </Widget>
    <Widget>
      <Name>LinkToView</Name>
      <Type>LinkToView</Type>
      <Location />
      <Extension />
    </Widget>
      <Name>MapMenu</Name>
      <Type>MapMenu</Type>
      <Location />
      <Extension>
        <Folder>
        </Folder>
      </Extension>
      <ImageClass>legend-map</ImageClass>
      <Label>Maps</Label>
      <Tooltip>Choose a map theme</Tooltip>
      <StatusText />
    </Widget>
      <Name>Maptip</Name>
      <Type>Maptip</Type>
      <Location />
      <Extension>
        <Delay>350</Delay>
        <Layer>
        </Layer>
        <Tolerance>2</Tolerance>
        <Target>MaptipWindow</Target>
        <WinFeatures>menubar=no,location=no,resizable=no,status=no</WinFeatures>
      </Extension>
      <ImageClass>maptip</ImageClass>
      <Label>Maptip</Label>
      <Tooltip>Click to Enable/Disable get information about features
from Server</Tooltip>
      <StatusText />
    </Widget>
    <Widget>
      <Name>Navigator</Name>
      <Type>Navigator</Type>
      <Location />
      <Extension />
    </Widget>
    <Widget>
      <Name>OverviewMap</Name>
      <Type>OverviewMap</Type>
      <Location />
      <Extension>
        <MapId>
        </MapId>
        <MinRatio>32</MinRatio>
        <MaxRatio>128</MaxRatio>
      </Extension>
    </Widget>
      <Name>Pan</Name>
      <Type>Pan</Type>
      <Location />
      <Extension />
      <ImageClass>pan</ImageClass>
      <Label>Pan</Label>
      <Tooltip>Click and drag to pan the map</Tooltip>
      <StatusText />
    </Widget>
      <Name>PanOnClick</Name>
      <Type>PanOnClick</Type>
      <Location />
      <Extension>
        <Percentage>75</Percentage>
        <Direction>none</Direction>
      </Extension>
      <ImageUrl />
      <ImageClass />
      <Label />
      <Tooltip />
      <StatusText />
    </Widget>
      <Name>PanQuery</Name>
      <Type>PanQuery</Type>
      <Location />
      <Extension>
        <SelectionType>INTERSECTS</SelectionType>
        <Tolerance>3</Tolerance>
        <QueryActiveLayer>false</QueryActiveLayer>
      </Extension>
      <Label>Pan query</Label>
      <Tooltip>Drag the mouse to pan, click to query</Tooltip>
      <StatusText />
    </Widget>
      <Name>Print</Name>
      <Type>Print</Type>
      <Location />
      <Extension>
        <ShowPrintUI>true</ShowPrintUI>
        <ShowTitle>false</ShowTitle>
        <PageTitle>
        </PageTitle>
        <ShowLegend>false</ShowLegend>
        <ShowNorthArrow>false</ShowNorthArrow>
        <ImageBaseUrl>
        </ImageBaseUrl>
      </Extension>
      <ImageClass>file-print</ImageClass>
      <Label>Print</Label>
      <Tooltip>Print the current map view</Tooltip>
      <StatusText />
    </Widget>
      <Name>Query</Name>
      <Type>Query</Type>
      <Location />
      <Extension>
      </Extension>
      <ImageClass>query</ImageClass>
      <Label>Query</Label>
      <Tooltip>Click to execute a custom query</Tooltip>
      <StatusText />
    </Widget>
      <Name>QuickPlot</Name>
      <Type>QuickPlot</Type>
      <Location />
      <Extension>
        <RememberPlotOptions>false</RememberPlotOptions>
        <ShowCoordinateLabels>true</ShowCoordinateLabels>
        <ShowSubTitle>true</ShowSubTitle>
        <DefaultDpi>96</DefaultDpi>
        <PaperListEntry>
        </PaperListEntry>
        <ScaleListEntry>
        </ScaleListEntry>
        <DefaultMargin>25.4,12.7,12.7,12.7</DefaultMargin>
        <Disclaimer>The materials available at this web site are for
informational purposes only and do not constitute a legal
document.</Disclaimer>
        <AllowDisclaimerToggle>true</AllowDisclaimerToggle>
        <ShowCoordinates>false</ShowCoordinates>
        <ShowScaleBar>false</ShowScaleBar>
        <ShowLegalDisclaimer>true</ShowLegalDisclaimer>
      </Extension>
      <ImageUrl>images/icons/print.png</ImageUrl>
      <ImageClass />
      <Label>Quick Plot</Label>
      <Tooltip>Click to create a plot quickly</Tooltip>
      <StatusText />
    </Widget>
      <Name>Redline</Name>
      <Type>Redline</Type>
      <Location />
      <Extension>
        <AutogenerateLayerNames>true</AutogenerateLayerNames>
        <UseMapMessage>true</UseMapMessage>
        <DataStoreFormat>
        </DataStoreFormat>
        <RedlineGeometryFormat>7</RedlineGeometryFormat>
        <AutoCreateOnStartup>true</AutoCreateOnStartup>
        <StylizationType>basic</StylizationType>
      </Extension>
      <ImageClass>redline</ImageClass>
      <Label>Redline</Label>
      <Tooltip>Click to draw redline features</Tooltip>
      <StatusText />
    </Widget>
      <Name>RefreshMap</Name>
      <Type>RefreshMap</Type>
      <Location />
      <Extension />
      <ImageClass>view-refresh</ImageClass>
      <Label>Refresh</Label>
      <Tooltip>Click to redraw the map</Tooltip>
      <StatusText />
    </Widget>
      <Name>SaveMap</Name>
      <Type>SaveMap</Type>
      <Location />
      <Extension>
        <Format>png</Format>
        <Scale>
        </Scale>
        <ResourceId>
        </ResourceId>
      </Extension>
      <ImageClass>file-save</ImageClass>
      <Label>Save map</Label>
      <Tooltip>Click to save the map as an image</Tooltip>
      <StatusText />
    </Widget>
    <Widget>
      <Name>Scalebar</Name>
      <Type>Scalebar</Type>
      <Location />
      <Extension>
        <Style>thin</Style>
        <DisplaySystem>metric</DisplaySystem>
        <MinWidth>100</MinWidth>
        <MaxWidth>200</MaxWidth>
        <Divisions>2</Divisions>
        <SubDivisions>2</SubDivisions>
        <ShowMinorMeasures>true</ShowMinorMeasures>
        <AbbreviateLabel>true</AbbreviateLabel>
        <SingleLine>false</SingleLine>
      </Extension>
    </Widget>
    <Widget>
      <Name>ScalebarDual</Name>
      <Type>ScalebarDual</Type>
      <Location />
      <Extension>
        <MaxWidth>300</MaxWidth>
        <TopInUnits>ft</TopInUnits>
        <TopOutUnits>mi</TopOutUnits>
        <BottomInUnits>m</BottomInUnits>
        <BottomOutUnits>km</BottomOutUnits>
      </Extension>
    </Widget>
      <Name>Select</Name>
      <Type>Select</Type>
      <Location />
      <Extension>
      </Extension>
      <ImageClass>select</ImageClass>
      <Label>Select</Label>
      <Tooltip>Click to select features</Tooltip>
      <StatusText />
    </Widget>
    <Widget>
      <Name>SelectionPanel</Name>
      <Type>SelectionPanel</Type>
      <Location />
      <Extension>
        <PreviousImageUrl>
        </PreviousImageUrl>
        <NextImageUrl>
        </NextImageUrl>
        <ResultsPerPage>0</ResultsPerPage>
        <SelectionRenderer>Fusion.Widget.SelectionPanel.SelectionRendererDefault</SelectionRenderer>
      </Extension>
    </Widget>
      <Name>SelectPolygon</Name>
      <Type>SelectPolygon</Type>
      <Location />
      <Extension>
      </Extension>
      <ImageClass>select-polygon</ImageClass>
      <Label>Select Polygon</Label>
      <Tooltip>Draw a polygon to perform a selection</Tooltip>
      <StatusText />
    </Widget>
      <Name>SelectRadius</Name>
      <Type>SelectRadius</Type>
      <Location />
      <Extension>
        <DefaultRadius>20</DefaultRadius>
        <RadiusTooltipContainer>
        </RadiusTooltipContainer>
        <RadiusTooltipType>dynamic</RadiusTooltipType>
      </Extension>
      <ImageClass>select-radius</ImageClass>
      <Label>Select Radius</Label>
      <Tooltip>Click to select within a radius</Tooltip>
      <StatusText />
    </Widget>
      <Name>SelectRadiusValue</Name>
      <Type>SelectRadiusValue</Type>
      <Location />
      <Extension>
        <RadiusName>SelectRadius</RadiusName>
        <Label>
        </Label>
        <ClassName>
        </ClassName>
      </Extension>
      <ImageUrl />
      <ImageClass />
      <Label>Select radius value</Label>
      <Tooltip>enter the radius for the Select by Radius tool</Tooltip>
      <StatusText />
    </Widget>
      <Name>SelectWithin</Name>
      <Type>SelectWithin</Type>
      <Location />
      <Extension>
        <DisableIfSelectionEmpty>true</DisableIfSelectionEmpty>
        <OmitInvisibleLayers>false</OmitInvisibleLayers>
      </Extension>
      <ImageClass>select-features</ImageClass>
      <Label>Select within</Label>
      <Tooltip>Click to select features within this selection</Tooltip>
      <StatusText />
    </Widget>
    <Widget>
      <Name>TaskPane</Name>
      <Type>TaskPane</Type>
      <Location />
      <Extension>
        <InitialTask>
        </InitialTask>
        <MenuContainer>TaskMenu</MenuContainer>
      </Extension>
    </Widget>
      <Name>Theme</Name>
      <Type>Theme</Type>
      <Location />
      <Extension>
      </Extension>
      <ImageClass>theme</ImageClass>
      <Label>Theme</Label>
      <Tooltip>Click to create a themed layer</Tooltip>
      <StatusText />
    </Widget>
      <Name>ViewOptions</Name>
      <Type>ViewOptions</Type>
      <Location />
      <Extension>
        <DisplayUnits>
        </DisplayUnits>
      </Extension>
      <Label>Options</Label>
      <Tooltip>Click to change the units displayed</Tooltip>
      <StatusText />
    </Widget>
      <Name>Zoom</Name>
      <Type>Zoom</Type>
      <Location />
      <Extension>
        <Tolerance>5</Tolerance>
        <Factor>2</Factor>
        <Direction>in</Direction>
      </Extension>
      <ImageClass>zoom-in</ImageClass>
      <Label>Zoom Rectangle</Label>
      <Tooltip>Click or click and drag on the map to zoom in</Tooltip>
      <StatusText>Click or click and drag on the map to zoom in</StatusText>
    </Widget>
      <Name>ZoomToSelection</Name>
      <Type>ZoomToSelection</Type>
      <Location />
      <Extension>
        <MaximumZoomDimension>-1</MaximumZoomDimension>
        <ZoomFactor>2</ZoomFactor>
      </Extension>
      <ImageClass>select-zoom</ImageClass>
      <Label>Zoom Selection</Label>
      <Tooltip>Click to zoom to the selection</Tooltip>
      <StatusText />
    </Widget>
      <Name>ZoomIn</Name>
      <Type>ZoomOnClick</Type>
      <Location />
      <Extension>
        <Factor>2</Factor>
      </Extension>
      <ImageClass>zoom-in-fixed</ImageClass>
      <Label>Zoom In</Label>
      <Tooltip>Zoom in by a preset increment</Tooltip>
      <StatusText>Zoom in by a preset increment</StatusText>
    </Widget>
      <Name>ZoomOut</Name>
      <Location />
      <Extension>
        <Factor>0.5</Factor>
      </Extension>
      <ImageClass>zoom-out-fixed</ImageClass>
      <Label>Zoom Out</Label>
      <Tooltip>Zoom out by a preset increment</Tooltip>
      <StatusText>Zoom out by a preset increment</StatusText>
    </Widget>
      <Name>PreviousView</Name>
      <Type>ExtentHistory</Type>
      <Location />
      <Extension>
        <Direction>previous</Direction>
      </Extension>
      <ImageClass>view-back</ImageClass>
      <Label>Previous</Label>
      <Tooltip>Go to previous view</Tooltip>
      <StatusText>Go to previous view</StatusText>
    </Widget>
      <Name>NextView</Name>
      <Location />
      <Extension>
        <Direction>next</Direction>
      </Extension>
      <ImageClass>view-forward</ImageClass>
      <Label>Next</Label>
      <Tooltip>Go to next view</Tooltip>
      <StatusText>Go to next view</StatusText>
    </Widget>
      <Name>tbBuffer</Name>
      <Location />
      <Extension>
      </Extension>
      <Tooltip>Measure distances and areas on the map</Tooltip>
      <StatusText>Create buffers around the selected features</StatusText>
    </Widget>
      <Name>Measure</Name>
      <Type>Measure</Type>
      <Location />
      <Extension>
        <Type>both</Type>
        <MeasureTooltipContainer>MeasureResult</MeasureTooltipContainer>
        <MeasureTooltipType>dynamic</MeasureTooltipType>
        <DistancePrecision>0</DistancePrecision>
        <AreaPrecision>0</AreaPrecision>
        <Units>meters</Units>
      </Extension>
      <ImageClass>measure</ImageClass>
      <Label>Measure</Label>
      <Tooltip>Measure</Tooltip>
      <StatusText>Measure distances and areas on the map</StatusText>
    </Widget>
      <Name>showOverview</Name>
      <Type>InvokeScript</Type>
      <Location />
      <Extension>
        <Script>showOverviewMap()</Script>
      </Extension>
      <ImageUrl />
      <ImageClass />
      <Label>Show Overview</Label>
      <Tooltip />
      <StatusText />
    </Widget>
      <Name>showTaskPane</Name>
      <Location />
      <Extension>
        <Script>showTaskPane()</Script>
      </Extension>
      <ImageUrl />
      <ImageClass />
      <Label>Show Task Pane</Label>
      <Tooltip />
      <StatusText />
    </Widget>
      <Name>showLegend</Name>
      <Location />
      <Extension>
        <Script>showLegend()</Script>
      </Extension>
      <ImageUrl />
      <ImageClass />
      <Label>Show Legend</Label>
      <Tooltip />
      <StatusText />
    </Widget>
      <Name>showSelectionPanel</Name>
      <Location />
      <Extension>
        <Script>showSelectionPanel()</Script>
      </Extension>
      <ImageUrl />
      <ImageClass />
      <Label>Show Selection Panel</Label>
      <Tooltip />
      <StatusText />
    </Widget>
    <Widget>
      <Name>statusCoordinates</Name>
      <Type>CursorPosition</Type>
      <Location />
      <Extension>
        <Template>X: {x} {units}, Y: {y} {units}</Template>
        <DisplayProjection>
        </DisplayProjection>
        <Units>dd</Units>
        <EmptyText>&amp;nbsp;</EmptyText>
      </Extension>
    </Widget>
    <Widget>
      <Name>statusSelection</Name>
      <Type>SelectionInfo</Type>
      <Location />
      <Extension>
        <Template>{0} feature(s) selected on {1} layer(s)</Template>
        <EmptyText>No selection</EmptyText>
      </Extension>
    </Widget>
    <Widget>
      <Name>statusViewSize</Name>
      <Type>ViewSize</Type>
      <Location />
      <Extension>
        <Units>Meters</Units>
        <Precision>2</Precision>
        <Template>{w} x {h} ({units})</Template>
      </Extension>
    </Widget>
      <Name>vertZoomIn</Name>
      <Location />
      <Extension>
        <Factor>2</Factor>
      </Extension>
      <Label />
    </Widget>
      <Name>vertZoomOut</Name>
      <Location />
      <Extension>
      </Extension>
      <Label />
    </Widget>
      <Name>vertPreviousView</Name>
      <Location />
      <Extension>
      </Extension>
      <Label />
    </Widget>
      <Name>vertNextView</Name>
      <Location />
      <Extension>
      </Extension>
      <Label />
    </Widget>
      <Name>vertSelect</Name>
      <Type>Select</Type>
      <Location />
      <Extension>
      </Extension>
      <Label />
      <StatusText />
    </Widget>
      <Name>vertPan</Name>
      <Type>Pan</Type>
      <Location />
      <Extension />
      <Label />
      <StatusText />
    </Widget>
      <Name>vertZoom</Name>
      <Type>Zoom</Type>
      <Location />
      <Extension>
        <Factor>2</Factor>
      </Extension>
      <Label />
    </Widget>
      <Name>vertInitialMapView</Name>
      <Location />
      <Extension>
      </Extension>
      <Label />
      <StatusText />
    </Widget>
      <Name>vertZoomToSelection</Name>
      <Location />
      <Extension>
      </Extension>
      <Label />
      <StatusText />
    </Widget>
      <Name>demoComponentTest</Name>
      <Type>InvokeURL</Type>
      <Location />
      <Extension>
        <Url>component://DemoComponent</Url>
        <DisableIfSelectionEmpty>false</DisableIfSelectionEmpty>
        <AdditionalParameter />
      </Extension>
      <ImageUrl />
      <ImageClass />
      <Label>Demo Component</Label>
      <Tooltip />
      <StatusText />
    </Widget>
      <Name>messageComponent</Name>
      <Location />
      <Extension>
        <Target>InvokeUrlWindow</Target>
        <Url>component://MessagesComponent</Url>
      </Extension>
      <ImageUrl />
      <ImageClass />
      <Label>Messages Component</Label>
      <Tooltip />
      <StatusText />
    </Widget>
      <Name>ViewAsKml</Name>
      <Location />
      <Extension>
        <Script />
      </Extension>
      <ImageUrl />
      <ImageClass />
      <Label>View as KML</Label>
      <Tooltip />
      <StatusText />
    </Widget>
  </WidgetSet>
  <Extension>
    <OpenStreetMapScript>http://www.openstreetmap.org/openlayers/OpenStreetMap.js</OpenStreetMapScript>
  </Extension>
</ApplicationDefinition>
On Thu, 15 Sept 2022 at 11:38, Kajar Kuldsepp <kajar.kuldsepp at gmail.com>
wrote:
> Hi!
> using latest 0.14.7 version.
>    - Could not find the context menu configuration. Right-clicking the
>    map will show an empty context menu. If you are loading from a Flexible
>    Layout, it must have a container named 'MapContextMenu'
> templates.
> but still same warning on load. Does anyone else have experienced same
> problem and how to get rid of it?
> Kajar
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220916/d2b4459f/attachment.htm>
