[mapguide-users] Mapguide 3.1.0 and PostgreSQL v14
Jackie Ng jumpinjackie at gmail.com
Fri Sep 16 03:41:17 PDT 2022
libpq should be highly source and binary compatible, so if the libpq.dll
you're using is too old, you should be able to replace it with a newer
version and things should still work.
- Jackie
You wrote:
Hi List,
We have been using Mapguide (3.1.0) for a very long time with great
satisfaction with Oracle Spatial and PostgreSQL/PostGIS as datasource.
We would now like to connect to PostgreSQL version 14. This does not
seem technically possible since the version of the Postgre SQL client
(libpq.dll) used by Mapguide  is lower than 10. So I would like to
know if I could install a newer version of the postgre client with our
version 3.1 of Mapguide?
Thanks for your Help
Ludovic
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220916/5ab861c1/attachment.htm>
