[mapguide-users] R: Cannot connect MapGuide 3.1.2 to OrcaleClient
Giovanni Tommasi giovanni.tommasi at abitat.it
Thu Sep 29 07:20:43 PDT 2022
in other similar context you have to use Oracle client 32-bit for 32-bit application and Oracle client 64-bit for 64-bit application.
You can also install both client, in the worst case :)
Could you check the version of MapGuide installed and the Oracle client?
Best regards
Giovanni
Da: mapguide-users <mapguide-users-bounces at lists.osgeo.org> Per conto di Gunter Becker
Inviato: giovedì 29 settembre 2022 16:13
A: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Oggetto: [mapguide-users] Cannot connect MapGuide 3.1.2 to OrcaleClient
I have to reinstall our WebMapping-Application on a Windows Server 2019 but have no luck in connecting MapGuide to an Oracle Database.
The error I get is:
ORA-12154 - TNS:could not resolve the connect identifier specified
I'va already installed Orcale client (v12) and confirmed that it connects correctly to he DB (v11) via tnsping and SQLPlus.
Additionally I also tested the connection with the newest version of FDO Toolbox which works just fine.
I'm also aware of newer dll's for client v12 that I found on osgeo.org and I replaced the old ones for oracle client v11.
And I also tried the dll from FDO Toolbox.
So I'm running out of ideas how I can resolve the connction problem.
Any help is highly appreciatedMapGuide.
Thanks, Gunter
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220929/10d948f2/attachment.htm>
