[mapguide-users] Google street view fail (not able to transform the map to EPSG:4326)
Hadis Alinia
hadissaalinia at gmail.com
Thu Sep 29 10:09:08 PDT 2022
Hi Gordon,
Thank you for your email. By changing the main map to LL84, my layers
disappears from the maps view and I can't see any of my maps and even the
basemaps.
The projection that I am currently using and working well to display all
the layers is:
"PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular
Visualisation Pseudo
Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]"
Is it something that I need to change in Google Street viewer.js?
Hadis
On Thu, Sep 29, 2022 at 5:34 AM Gordon Luckett <
gordon.luckett at arrowgeomatics.com> wrote:
> If you set your main map to LL84, does Google Street view work?
> On Wed., Sep. 28, 2022, 1:39 p.m. Hadis Alinia, <hadissaalinia at gmail.com>
> wrote:
>> Hi,
>> I am trying to have google street view on my fusion map. I added the
>> widget and I can see the icon added to my webpage and also turned on the
>> google street base map.
>> But when I click on the "Google Street View" icon I get the following
>> error: "The CS of current map can not be transformed to EPSG: 2346". The
>> coordinate system of my map to overlay the layers is WGS84.PseudoMercator
>> as was mentioned in the instruction.
>> I hope you can help me to fix this problem.
>> Thank you
>> Hadis
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220929/fde53ddf/attachment.htm>
