[mapguide-users] Google street view fail (not able to transform the map to EPSG:4326)
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Fri Sep 30 13:23:07 PDT 2022
Ensure you have assigned a coordinate system to your data (data sources).
If you change your coordinate system of the map, all the layers should
re-project if MapGuide knows what coordinate system the layers are in.
Once you solve this problem, I would then check the Street View with the
LL84 map (4326).
On Thu, Sep 29, 2022 at 1:09 PM Hadis Alinia <hadissaalinia at gmail.com>
wrote:
> Hi Gordon,
> Thank you for your email. By changing the main map to LL84, my layers
> disappears from the maps view and I can't see any of my maps and even the
> basemaps.
> The projection that I am currently using and working well to display all
> the layers is:
> "PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular
> Visualisation Pseudo
> Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]"
> Is it something that I need to change in Google Street viewer.js?
> Hadis
> On Thu, Sep 29, 2022 at 5:34 AM Gordon Luckett <
> gordon.luckett at arrowgeomatics.com> wrote:
>> If you set your main map to LL84, does Google Street view work?
>> On Wed., Sep. 28, 2022, 1:39 p.m. Hadis Alinia, <hadissaalinia at gmail.com>
>> wrote:
>>> Hi,
>>> I am trying to have google street view on my fusion map. I added the
>>> widget and I can see the icon added to my webpage and also turned on the
>>> google street base map.
>>> But when I click on the "Google Street View" icon I get the following
>>> error: "The CS of current map can not be transformed to EPSG: 2346". The
>>> coordinate system of my map to overlay the layers is WGS84.PseudoMercator
>>> as was mentioned in the instruction.
>>> I hope you can help me to fix this problem.
>>> Thank you
>>> Hadis
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220930/085a5e5b/attachment.htm>
