[mapguide-users] Google street view fail (not able to transform the map to EPSG:4326)
Hadis Alinia hadissaalinia at gmail.com
Fri Sep 30 18:41:05 PDT 2022
Hi Gordon,
Thank you for the solution! It worked well.
Hadis
On Fri, Sep 30, 2022 at 4:24 PM Gordon Luckett <
gordon.luckett at arrowgeomatics.com> wrote:
> Ensure you have assigned a coordinate system to your data (data sources).
> If you change your coordinate system of the map, all the layers should
> re-project if MapGuide knows what coordinate system the layers are in.
> Once you solve this problem, I would then check the Street View with the
> LL84 map (4326).
> On Thu, Sep 29, 2022 at 1:09 PM Hadis Alinia <hadissaalinia at gmail.com>
> wrote:
>> Hi Gordon,
>> Thank you for your email. By changing the main map to LL84, my layers
>> disappears from the maps view and I can't see any of my maps and even the
>> basemaps.
>> The projection that I am currently using and working well to display all
>> the layers is:
>> "PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular
>> Visualisation Pseudo
>> Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]"
>> Is it something that I need to change in Google Street viewer.js?
>> Hadis
>> On Thu, Sep 29, 2022 at 5:34 AM Gordon Luckett <
>>> If you set your main map to LL84, does Google Street view work?
>>> On Wed., Sep. 28, 2022, 1:39 p.m. Hadis Alinia, <hadissaalinia at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I am trying to have google street view on my fusion map. I added the
>>>> widget and I can see the icon added to my webpage and also turned on the
>>>> google street base map.
>>>> But when I click on the "Google Street View" icon I get the following
>>>> error: "The CS of current map can not be transformed to EPSG: 2346". The
>>>> coordinate system of my map to overlay the layers is WGS84.PseudoMercator
>>>> as was mentioned in the instruction.
>>>> I hope you can help me to fix this problem.
>>>> Thank you
>>>> Hadis
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220930/e46b68e1/attachment.htm>
