[mapguide-users] DB XML Error and Packages
David Bowen
dbowenrci at gmail.com
Fri Apr 14 05:54:42 PDT 2023
Based on articles I've come across online, it seems that the following
settings have resolved the issue:
LibraryCacheSize = 32
#SessionCacheSize = 2
SessionCacheSize = 4
DBPageSize = 32
DBXMLPageSize = 32
LibraryLogBufferSize = 12
SessionLogBufferSize = 1
#DBMaxTransactions = 1000
DBMaxTransactions = 2000
SessionDBPageSize = 2
SessionDBXMLPageSize = 0.5
#DBTimeout = 0.2
DBTimeout = 0.6
#DBMaxLockers = 1000
DBMaxLockers = 2000
On Fri, Mar 31, 2023 at 10:30 AM David Bowen <dbowenrci at gmail.com> wrote:
> I'm encountering an issue when trying to load packages using Maestro. For
> example, I'm attempting to load the package created from our Production
> environment into the Development environment and I get the following errors:
> The remote server returned an error: (559) MgDbXmlException.:
> An exception occurred in DB XML component.
> Error: DB_BUFFER_SMALL: User memory too small for return value
> - MgResourceServiceHandler.ProcessOperation() line 80 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
> - MgOpApplyResourcePackage.Execute() line 96 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\OpApplyResourcePackage.cpp
> - MgServerResourceService.ApplyResourcePackage() line 815 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\ServerResourceService.cpp
> - MgLibraryRepositoryManager.ApplyResourcePackage() line 148 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\LibraryRepositoryManager.cpp
> - MgLibraryRepositoryManager.LoadResourcePackage() line 183 file
> - MgResourcePackageLoader.Start() line 145 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\ResourcePackageLoader.cpp
> - MgResourcePackageLoader.PerformOperation() line 223 file
> - MgResourcePackageLoader.SetResource() line 303 file
> - MgRepositoryManager.SetResource() line 559 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\RepositoryManager.cpp
> - MgRepositoryManager.AddResource() line 532 file
> - MgResourceContentManager.AddResource() line 178 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\ResourceContentManager.cpp
> - MgResourceContentManager.PutDocument() line 619 file
> - MgResourceDefinitionManager.PutDocument
> (MgLibraryResourceContents.dbxml)() line 545 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
> System.Exception: The remote server returned an error: (559)
> MgDbXmlException.:
> ---> System.Net.WebException: The remote server returned an error: (559)
> MgDbXmlException.
> at System.Net.HttpWebRequest.GetResponse()
> at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.UploadPackage(String
> filename, StreamCopyProgressDelegate callback) in
> C:\projects\mapguide-maestro\OSGeo.MapGuide.MaestroAPI\Http\HttpServerConnection.cs:line
> 1511
> --- End of inner exception stack trace ---
> 1525
> at Maestro.Packaging.PackageBuilder.UploadPackage(String sourceFile) in
> C:\projects\mapguide-maestro\Maestro.Packaging\PackageBuilder.cs:line 183
> at
> Maestro.Packaging.PackageProgress.<>c__DisplayClass10_0.<UploadPackage>b__0()
> in C:\projects\mapguide-maestro\Maestro.Packaging\PackageProgress.cs:line
> 175
> at Maestro.Packaging.PackageProgress.backgroundWorker_DoWork(Object
> sender, DoWorkEventArgs e) in
> C:\projects\mapguide-maestro\Maestro.Packaging\PackageProgress.cs:line 395
> at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
> at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object
> argument)
> Based on previous threads, I've attempted to increase the following
> parameters in the serverconfig.ini file but have had no success.
> #SessionDBXMLPageSize = 0.5
> SessionDBXMLPageSize = 1.0
> #SessionDBPageSize = 2
> SessionDBPageSize = 4
> #SessionLogBufferSize = 1
> SessionLogBufferSize = 5
> #LibraryLogBufferSize = 12
> LibraryLogBufferSize = 24
> #DBXMLPageSize = 32
> DBXMLPageSize = 64
> #DBPageSize = 32
> DBPageSize = 64
> Has anyone else encountered this issue and have figured out a solution?
> Thanks,
> David
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230414/73a2ff18/attachment.htm>
