[mapguide-users] MapGuide MVT Tiles with view as source
Martin Herich
maherich at gis-services.sk
Fri Apr 28 02:30:07 PDT 2023
We are using TileSetDefinition with TileProvider set to XYZ and TileFormat set to MVT.
The problem we have is that all features inside the vector tiles have attribute "id" set to 0.
We have found out that the problem is that we are using view as the source data for layer. When we change the source data to table, then the features have the attribute "id" set to primary key value. The source data are stored in PostgreSQL database.
Is there some possibility to configure which column from the view should be used as the attribute "id" for the vector tile features?
Thank you for any hint,
Martin
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230428/b3f5fd7b/attachment.htm>
