[mapguide-users] north rotation
Jonathan Rizzo jrizzo at Langan.com
Mon Feb 13 06:30:40 PST 2023
Is there a way to pre-set the north rotation for a map, like you would set the initial zoom, so that when the map loads, north is some direction other than straight up?  If not, is this something that can make its way in to a future version?  The flexibility of not only allowing the user to spin a map, but also to pre-set this rotation on the initial load would be of great benefit to us.
Regards,
Jon
This message may contain confidential, proprietary, or privileged information. Confidentiality or privilege is not intended to be waived or lost by erroneous transmission of this message. If you receive this message in error, please notify the sender immediately by return email and delete this message from your system. Disclosure, use, distribution, or copying of a message or any of its attachments by anyone other than the intended recipient is strictly prohibited.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230213/fd860253/attachment.htm>
