[mapguide-users] north rotation
Gordon Luckett gordon.luckett at arrowgeomatics.com
Mon Feb 13 06:49:06 PST 2023
If you use the react viewer, you can access the openlayers rotation:
https://openlayers.org/en/latest/examples/rotation.html
On Mon., Feb. 13, 2023, 9:36 a.m. Jonathan Rizzo, <jrizzo at langan.com> wrote:
> Is there a way to pre-set the north rotation for a map, like you would set
> the initial zoom, so that when the map loads, north is some direction other
> than straight up?  If not, is this something that can make its way in to a
> future version?  The flexibility of not only allowing the user to spin a
> map, but also to pre-set this rotation on the initial load would be of
> great benefit to us.
> Regards,
> Jon
> This message may contain confidential, proprietary, or privileged
> information. Confidentiality or privilege is not intended to be waived or
> lost by erroneous transmission of this message. If you receive this message
> in error, please notify the sender immediately by return email and delete
> this message from your system. Disclosure, use, distribution, or copying of
> a message or any of its attachments by anyone other than the intended
> recipient is strictly prohibited.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230213/0ca1f91d/attachment.htm>
