[mapguide-users] Session Creation Issue
Adam Jamison
Adam.Jamison at portbris.com.au
Mon Jul 17 18:31:25 PDT 2023
Bingo!!!! that fix exposed an error message that led me to the cause and the fix (temporary fix at least)
Error message regarding this.displayDpi_ is set to 0!!!
So this led me to find what defines the display dpi in chrome, the zoom in zoom out function.
So to re-create the problem change the zoom scale in chrome to anything under 100%, mine was set to 90% reload the mapguide page and the error occurs. Seems to work fine when you scale everything up i.e. 200%
Haven't investigated any further to implement a complete fix but at least I have a solution for the few users that are experiencing this.
Much appreciate the quick investigation this has been something I couldn't pin point and seems I re-created on my test machine by chance the session / vpn thing was a bum steer haha.
Note:
This message is for the named person's use only. It may contain confidential, proprietary or legally privileged information. No confidentiality or privilege is waived or lost by any mistransmission. If you receive this message in error, please immediately delete it and all copies of it from your system, destroy any hard copies of it and notify the sender. You must not, directly or indirectly, use, disclose, distribute, print, or copy any part of this message if you are not the intended recipient. The Port of Brisbane reserves the right to monitor all e-mail communications through its networks.
If you have received this transmission in error please let us know by contacting us on +61 7 3258 4888 or by reply E-Mail to the sender.
Any views expressed in this message are those of the individual sender, except where the message states otherwise and the sender is authorised to state them to be the views of any such entity.
Thank You.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230718/f0643843/attachment.htm>
