[mapguide-users] Session Creation Issue
    Jackie Ng
    jumpinjackie at gmail.com
    Tue Jul 18 03:10:28 PDT 2023
WOW! Excellent observation!
I've identified the issue of where the dpi = 0 is coming from and have made
this fix allowing the viewer to work with sub-100% browser zoom:
https://github.com/jumpinjackie/mapguide-react-layout/commit/f896eb7a68f52d3f71b3ab5e2beadee41eb4fed0
I will put out a new 0.14.9 release shortly with this fix among other
changes.
Once again, thanks for your keen observation.
Regards,
- Jackie
You wrote:
Bingo!!!! that fix exposed an error message that led me to the cause
and the fix (temporary fix at least)
Error message regarding this.displayDpi_ is set to 0!!!
So this led me to find what defines the display dpi in chrome, the
zoom in zoom out function.
So to re-create the problem change the zoom scale in chrome to
anything under 100%, mine was set to 90% reload the mapguide page and
the error occurs. Seems to work fine when you scale everything up i.e.
200%
Haven't investigated any further to implement a complete fix but at
least I have a solution for the few users that are experiencing this.
Much appreciate the quick investigation this has been something I
couldn't pin point and seems I re-created on my test machine by chance
the session / vpn thing was a bum steer haha.
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230718/d6e00d1c/attachment.htm>
