[mapguide-users] fusion theme -No access control allow origin error
pierre.cardinal at sympatico.ca
Tue Jun 6 06:29:42 PDT 2023
Hi Hadis,
More exact numbers
If you are designing a map you plan on overlaying over google maps or virtual earth and creating a tiling scheme then i think what you are looking for are the scales for each zoom level, use these:
19 : 1128.497220
18 : 2256.994440
17 : 4513.988880
16 : 9027.977761
15 : 18055.955520
14 : 36111.911040
13 : 72223.822090
12 : 144447.644200
11 : 288895.288400
10 : 577790.576700
9 : 1155581.153000
8 : 2311162.307000
7 : 4622324.614000
6 : 9244649.227000
5 : 18489298.450000
4 : 36978596.910000
3 : 73957193.820000
2 : 147914387.600000
1 : 295828775.300000
0 : 591657550.500000
<https://gis.stackexchange.com/questions/7430/what-ratio-scales-do-google-maps-zoom-levels-correspond-to> https://gis.stackexchange.com/questions/7430/what-ratio-scales-do-google-maps-zoom-levels-correspond-to
Regards,
Pierre
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de pierre.cardinal at sympatico.ca
Envoyé : 6 juin 2023 09:21
À : 'MapGuide Users Mail List' <mapguide-users at lists.osgeo.org>
Objet : Re: [mapguide-users] fusion theme -No access control allow origin error
Hi Hadis,
Google satellite data are available for zooms between 0 and 7 (xmax and ymax are 127). To avoid the pink tiles, you should limit the maximum scale factor (or Min Scale for layer config) to display your layer.
Level
# Tiles
Tile width
(° of longitudes)
m / pixel
(on Equator)
~ Scale
(on screen)
Examples of
areas to represent
0
1
360
156 543
1:500 million
whole world
1
4
180
78 272
1:250 million
2
16
90
39 136
1:150 million
subcontinental area
3
64
45
19 568
1:70 million
largest country
4
256
22.5
9 784
1:35 million
5
1 024
11.25
4 892
1:15 million
large African country
6
4 096
5.625
2 446
1:10 million
large European country
7
16 384
2.813
1 223
1:4 million
small country, US state
<https://wiki.openstreetmap.org/wiki/Zoom_levels> https://wiki.openstreetmap.org/wiki/Zoom_levels
Regards,
Pierre
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org <mailto:mapguide-users-bounces at lists.osgeo.org> > De la part de Hadis Alinia
Envoyé : 5 juin 2023 23:22
À : MapGuide Users Mail List <mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org> >
Pierre
Thank you for your response. By replacing that with <https://mt0.google.com/vt/lyrs=m&hl=en&x=$%7bx%7d&y=$%7by%7d&z=$%7bz%7d> https://mt0.google.com/vt/lyrs=m&hl=en&x=${x}&y=${y}&z=${z} still I get the error and I see the pink background with no map. However, by using the example tile and specifying <https://mt0.google.com/vt/lyrs=s&x=1&y=1&z=2> x=1&y=1&z=2 I see the tiles (multiple similar tiles in the fusion) showing somewhere in the world. And when I use the Theme widget it classifies the layer and the tiles are still there. It looks like I am getting close to the right answers and have the background map with the themed layer.
My question is how to get the right tile location and scale that is matched my layer's bounding box.
Thank you
Hadis
On Mon, Jun 5, 2023 at 7:11 PM Pierre Cardinal < <mailto:pierre.cardinal at sympatico.ca> pierre.cardinal at sympatico.ca> wrote:
The tile <https://mt1.google.com/vt/lyrs=s&x=262143&y=262143&z=19> https://mt1.google.com/vt/lyrs=s&x=262143&y=262143&z=19 does not exist. Example of a valid one <https://mt0.google.com/vt/lyrs=s&x=1&y=1&z=2> https://mt0.google.com/vt/lyrs=s&x=1&y=1&z=2
Regards,
Pierre
_____
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org <mailto:mapguide-users-bounces at lists.osgeo.org> > de la part de Hadis Alinia <hadissaalinia at gmail.com <mailto:hadissaalinia at gmail.com> >
Envoyé : lundi, juin 5, 2023 2:38:40 p.m.
Objet : [mapguide-users] fusion theme -No access control allow origin error
I am using MG version 3.1.2 on IIS. On the fusion, when I use the Theme widget I get the themed layers and it's added to the legend but the base map of Openstreet doesn't load and the cursor spins forever. By Looking at the errors in the console I see the 100 errors of "access to the image at <https://c.tile.openstreetmap.org/5.379310131539869/13/13.png> https://c.tile.openstreetmap.org/5.379310131539869/13/13.png from the origin my website address has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource" and the same error for <https://b.tile> https://b.tile and a.tile.
Just letting you know I tried adding and removing basemaps even Generic XYZs still get the same results and error.
Removing the openstreet map and with Generic XYZ for google street I get the error as follows:
GET <https://mt1.google.com/vt/lyrs=s&x=262143&y=262143&z=19> https://mt1.google.com/vt/lyrs=s&x=262143&y=262143&z=19 404
Image (async)
setImgSrc
fusionSF.js:72880
initImage
fusionSF.js:72856
renderTile
fusionSF.js:72725
draw
fusionSF.js:72698
initGriddedTiles
fusionSF.js:81293
moveTo
fusionSF.js:80764
redraw
fusionSF.js:56355
redraw
fusionSF.js:80161
setVisibility
fusionSF.js:56531
setBaseLayer
fusionSF.js:54205
removeLayer
fusionSF.js:54084
layerLoaded
fusionSF.js:111583
(anonymous)
fusionSF.js:46681
triggerEvent
fusionSF.js:108396
onRuntimeMapCreated
fusionSF.js:131138
(anonymous)
fusionSF.js:46681
respondToReadyState
fusionSF.js:97102
onStateChange
fusionSF.js:97005
(anonymous)
fusionSF.js:46681
XMLHttpRequest.send (async)
request
fusionSF.js:96987
initialize
fusionSF.js:96931
dispatchRequest
fusionSF.js:109871
loadMap
fusionSF.js:130574
mapSessionCreated
fusionSF.js:130510
initialize
fusionSF.js:130409
loadMapGroup
fusionSF.js:111501
initialize
fusionSF.js:111397
create
fusionSF.js:109118
create
fusionSF.js:108672
setLoadState
fusionSF.js:521
scriptLoaded
fusionSF.js:639
(anonymous)
fusionSF.js:46681
load (async)
queueScript
fusionSF.js:594
require
fusionSF.js:1156
(anonymous)
fusionSF.js:119177
I would appreciate it if please assist me to solve this issue.
Thanks
Hadis
mapguide-users mailing list
<mailto:mapguide-users at lists.osgeo.org> mapguide-users at lists.osgeo.org
<https://lists.osgeo.org/mailman/listinfo/mapguide-users> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230606/b991eeb5/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230606/b991eeb5/attachment.png>
