[mapguide-users] MGOS 4 Beta 1 and Packages not Loading
Jackie Ng jumpinjackie at gmail.com
Wed Jun 14 07:01:26 PDT 2023
The mgserver.exe executable in MGOS 4.0 beta 1 supports package loading
from the command-line:
mgserver.exe loadpackage <path to package file>
Does this new method for loading packages work for you?
Also: If you are using transactional package loading in Maestro, it does
not work in the current release:
https://jumpinjackie.github.io/mapguide-maestro/userguide/known_issues.html
- Jackie
You wrote:
We're encountering an issue where we can't load packages using the MapGuide
Site Administrator portal in MapGuide 4.0 Beta 1. This is a relatively new
issue that I haven't encountered before. In MGOS 3.1, when you load a
package, a new page would be displayed with the message "The package is
currently loading [...] of the Site Administrator". In MGOS 4 Beta 1, that
page isn't being displayed and it doesn't appear that the package is
successfully loaded as the “Status” field remains unchanged for the
selected package.
When I try to load the package using Maestro, the pop-up window that
displays the progress closes without a notice of the load being successful
or not.
Thanks,
David
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230615/ee5228d4/attachment.htm>
