[mapguide-users] MGOS 4 Beta 1 and Packages not Loading
David Bowen dbowenrci at gmail.com
Wed Jun 14 07:48:51 PDT 2023
Thanks Jackie. The command-line script worked perfectly. I was using the
transactional method to try to load the package using Maestro so that would
explain that aspect failing.
Regards,
David
On Wed, Jun 14, 2023 at 10:30 AM Jackie Ng <jumpinjackie at gmail.com> wrote:
> The mgserver.exe executable in MGOS 4.0 beta 1 supports package loading
> from the command-line:
> mgserver.exe loadpackage <path to package file>
> Does this new method for loading packages work for you?
> Also: If you are using transactional package loading in Maestro, it does
> not work in the current release:
> https://jumpinjackie.github.io/mapguide-maestro/userguide/known_issues.html
> - Jackie
> You wrote:
> We're encountering an issue where we can't load packages using the MapGuide
> Site Administrator portal in MapGuide 4.0 Beta 1. This is a relatively new
> issue that I haven't encountered before. In MGOS 3.1, when you load a
> package, a new page would be displayed with the message "The package is
> currently loading [...] of the Site Administrator". In MGOS 4 Beta 1, that
> page isn't being displayed and it doesn't appear that the package is
> successfully loaded as the “Status” field remains unchanged for the
> selected package.
> When I try to load the package using Maestro, the pop-up window that
> displays the progress closes without a notice of the load being successful
> or not.
> Thanks,
> David
> *Please Note: I no longer create new posts or post replies to any OSGeo
> mailing list through nabble. As a result, you most likely won't see this
> message appear on nabble's view of any OSGeo mailing list and may only see
> this message through mailing list archives or depending on your mailing
> list subscription settings, through daily message digests or automated
> notifications from the mailing lists.*
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230614/c83946ff/attachment.htm>
