[mapguide-users] Objet : Objet : make package mapadmin
anniechan03 at yahoo.com anniechan03 at yahoo.com
Thu Jun 15 14:22:39 PDT 2023
 yes. Thank only thing i didnt install was orable and mysql
    On Thursday, 15 June 2023 at 16:46:19 GMT-4, Pierre Cardinal <pierre.cardinal at sympatico.ca> wrote:
 #yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 p.yiv7764303899MsoNormal, #yiv7764303899 li.yiv7764303899MsoNormal, #yiv7764303899 div.yiv7764303899MsoNormal {margin:0cm;font-size:11.0pt;font-family:sans-serif;}#yiv7764303899 a:link, #yiv7764303899 span.yiv7764303899MsoHyperlink {color:blue;text-decoration:underline;}#yiv7764303899 p.yiv7764303899msonormal, #yiv7764303899 li.yiv7764303899msonormal, #yiv7764303899 div.yiv7764303899msonormal {margin-right:0cm;margin-left:0cm;font-size:11.0pt;font-family:sans-serif;}#yiv7764303899 p.yiv7764303899msonormal1, #yiv7764303899 li.yiv7764303899msonormal1, #yiv7764303899 div.yiv7764303899msonormal1 {margin:0cm;font-size:11.0pt;font-family:sans-serif;}#yiv7764303899 p.yiv7764303899msonormal2, #yiv7764303899 li.yiv7764303899msonormal2, #yiv7764303899 div.yiv7764303899msonormal2 {margin:0cm;font-size:11.0pt;font-family:sans-serif;}#yiv7764303899 span.yiv7764303899gmailsignatureprefix {}#yiv7764303899 .yiv7764303899MsoChpDefault {}#yiv7764303899 filtered {}#yiv7764303899 div.yiv7764303899WordSection1 {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 filtered {}#yiv7764303899 ol {margin-bottom:0cm;}#yiv7764303899 ul {margin-bottom:0cm;}
When you installed MapGuide did you installed the « MS SQL Server Spatial Provider » ?
Envoyé à partir de Courrier pour Windows
De : anniechan03 at yahoo.com
Envoyé le :15 juin 2023 16:41
À : MapGuide Users Mail List; Pierre Cardinal
Objet :Re: Objet : [mapguide-users] make package mapadmin
MS SQL
On Thursday, 15 June 2023 at 16:37:17 GMT-4, Pierre Cardinal <pierre.cardinal at sympatico.ca> wrote:
What kind of database do you want to connect to?  MySQL 5, MySQL 8, PostgreSQL, MS SQL, ...
Regards
Pierre
Envoyé le :15 juin 2023 11:19
À : mapguide-users at lists.osgeo.org
Objet :Re: [mapguide-users] make package mapadmin
Thank you guys! it worked
im still a newbie on it. So trying out different stuff.
Oh another thing that i am encountering as of the moment. Im trying to use sql server as a database, but when i try to add a feature in maestro and tried to connect to the DB. I am getting a mgfdoexception(559)
FDO Connection Status:
The remote server returned an error: (559) MgFdoException.: The custom error module does not recognize this error.
this is right after i click the "Test Connection" button, i know the user and PW is correct because i was able to connect to the db with sql mgmt studio.
I tried looking at the error.log on
C:\Program Files\OSGeo\MapGuide\Server\Logs
but found nothing about the 559 exception
I tried looking at the maestro folder but didnt see any log files there..
Is there something i am missing here or a place where i can look at the issue?
On Wednesday, 14 June 2023 at 08:01:57 GMT-4, Jackie Ng <jumpinjackie at gmail.com> wrote:
Root folder here means the folder in your site repository where you want to package all resources within it. So for example, if your site repository is laid out like this:
   - MyMap1
   - Data
   - Layers
   - Maps
   - Layouts
   - MyMap2
   - Data
   - Layers
   - Maps
   - Layouts
If you want to package everything under MyMap1, you would use either:
   - Library://MyMap1/
   - //MyMap1/
And if you load this package on a different MapGuide Server, it will re-create this folder structure on that MG server as part of loading all the packaged resources.
   - MyMap1
   - Data
   - Layers
   - Maps
   - Layouts
If you want to package everything in the site repository, you can use Library:// or //
You can only package a single folder with the mapadmin, you cannot package multiple different folders at the same time.
Hope that helps.
- Jackie
You wrote:
How do i make package on the mapadmin page? It quiet confuse about the syntax to use
| Folder name (e.g. Library://<root_folder>/<folder1>): |
root folder of what?
i tried to do
Library://Packages/Library://Backup/Library://Library://<server name>/packages/Library://<server name>/
still not working, can someone help me on this?
Thanks
Please Note: I no longer create new posts or post replies to any OSGeo mailing list through nabble. As a result, you most likely won't see this message appear on nabble's view of any OSGeo mailing list and may only see this message through mailing list archives or depending on your mailing list subscription settings, through daily message digests or automated notifications from the mailing lists.
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230615/dab72b79/attachment.htm>
