[mapguide-users] mapserver2017 + mgReact-0.14.8 Error - Unexpected token '<', "
Nimrod Cnaan
nimcnaan at gmail.com
Fri Jun 16 18:52:10 PDT 2023
Thank u Jack,
I will try to describe the problem in more detail.
If we run the Sheboygan.FlexibleLayouts.TurquoiseYellow.App...
> The App's url - https://[myserverip]/mapserver2017
/viewer/sidebar.html?resource=Library....
1. If resource parameter is not set, we get
[image: image.png]
2. If resource
= Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition
>> For *Chrom *& *Eadg*: Unfortunately there is no request failed nore
javascript error on the console.
Attached file is the Network *.Har files
>> In *Firefox*: We get massage - *An error occurred during startup*
JSON.parse: unexpected character at line 1 column 1 of the JSON data
With Warnings only
Ruleset ignored due to bad selector. blueprint.css:1
Error in parsing value for ‘-webkit-transition-duration’. Declaration
dropped. _card.scss:84:26
Error in parsing value for ‘transition-duration’. Declaration dropped.
_card.scss:84:26
Error in parsing value for ‘-webkit-transition-delay’. Declaration dropped.
_react-transition.scss:31:11
Error in parsing value for ‘transition-delay’. Declaration dropped.
_react-transition.scss:64:11
Unknown pseudo-class or pseudo-element ‘-ms-input-placeholder’. Ruleset
ignored due to bad selector. _common.scss:127:2
Unknown pseudo-class or pseudo-element ‘-ms-clear’. Ruleset ignored due to
bad selector. _editable-text.scss:105
Unknown property ‘-moz-outline-radius’. Declaration dropped. _mixins.scss
:77:2
Unknown property ‘-moz-outline-radius’. Declaration dropped. _controls.scss
:261:6
Ruleset ignored due to bad selector. _common.scss:177:2
Ruleset ignored due to bad selector. _common.scss:270:2
Ruleset ignored due to bad selector. _common.scss:142:2
Ruleset ignored due to bad selector. _common.scss:146:2
Ruleset ignored due to bad selector. _common.scss:151:2
ignored due to bad selector. _common.scss:173:2
Ruleset ignored due to bad selector. _common.scss:227:2
Ruleset ignored due to bad selector. _common.scss:233:2
Ruleset ignored due to bad selector. _common.scss:237:2
Ruleset ignored due to bad selector. _common.scss:242:2
Ruleset ignored due to bad selector. _common.scss:247:2
Unknown property ‘-moz-osx-font-smoothing’. Declaration dropped. _icons.scss
:16:2
bad selector. _input.scss:26
Unknown pseudo-class or pseudo-element ‘-ms-expand’. Ruleset ignored due to
bad selector. _html-select.scss:31
:16:2
:16:2
:16:2
:16:2
:16:2
:16:2
Error while fetching an original source: unsupported protocol for sourcemap
request
webpack://MapGuide/node_modules/@blueprintjs/core/src/components/tree/_tree.scss
Source URL:
בתאריך יום ד׳, 14 ביוני 2023 ב-15:04 מאת Jackie Ng <
jumpinjackie at gmail.com>:
> Always look at your browser dev tools and see if a network request failed
> or there is a javascript error on the console.
> The init error message almost always isn't useful (it's only marginally
> more user-friendly than a blank screen, but that's the best we can do), the
> real error can generally be found/revealed through the devtools.
> - Jackie
> You wrote:
> When using mgReact-0.14.8 on MapServer2017 windows machine, layout is not
> showing.
> Instead we get en error - Unexpected token '<', "
> [image: image.png]
> בכבוד רב,
> Nimrod Cnaan
> *Please Note: I no longer create new posts or post replies to any OSGeo
> mailing list through nabble. As a result, you most likely won't see this
> message appear on nabble's view of any OSGeo mailing list and may only see
> this message through mailing list archives or depending on your mailing
> list subscription settings, through daily message digests or automated
> notifications from the mailing lists.*
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
בכבוד רב,
*נמרוד כנען** | *גיאומינד שירותי GIS – פיתוח, ייעוץ ושירותי ענן
ישיר: 048101268 | נייד: 0525355483 | nimrod at geomind.co.il
נא בקרו באתר החדש שלנו http://geomind.co.il
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230617/92e775f3/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230617/92e775f3/attachment.png>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230617/92e775f3/attachment.obj>
