[mapguide-users] mapserver2017 + mgReact-0.14.8 Error - Unexpected token '<', "
Nimrod Cnaan nimcnaan at gmail.com
Fri Jun 16 20:44:47 PDT 2023
Thank u Jack,
> I will try to describe the problem in more detail.
> If we run the Sheboygan.FlexibleLayouts.TurquoiseYellow.App...
> > The App's url - https://[myserverip]/mapserver2017
> /viewer/sidebar.html?resource=Library....
> 1. If resource parameter is not set, we get
> [image: image.png]
> 2. If resource
> = Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition
> >> For *Chrom *& *Eadg*: Unfortunately there is no request failed nore
> javascript error on the console.
> >> In *Firefox*: We get the massage - *An error occurred during startup*
> JSON.parse: unexpected character at line 1 column 1 of the JSON data
> With Warnings only
> Ruleset ignored due to bad selector. blueprint.css:1
> Error in parsing value for ‘-webkit-transition-duration’. Declaration
> dropped. _card.scss:84:26
> Error in parsing value for ‘transition-duration’. Declaration dropped.
> _card.scss:84:26
> Error in parsing value for ‘-webkit-transition-delay’. Declaration dropped.
> _react-transition.scss:31:11
> Error in parsing value for ‘transition-delay’. Declaration dropped.
> _react-transition.scss:64:11
> Unknown pseudo-class or pseudo-element ‘-ms-input-placeholder’. Ruleset
> ignored due to bad selector. _common.scss:127:2
> Unknown pseudo-class or pseudo-element ‘-ms-clear’. Ruleset ignored due to
> bad selector. _editable-text.scss:105
> Unknown property ‘-moz-outline-radius’. Declaration dropped. _mixins.scss
> :77:2
> _controls.scss:261:6
> Ruleset ignored due to bad selector. _common.scss:177:2
> Ruleset ignored due to bad selector. _common.scss:270:2
> Ruleset ignored due to bad selector. _common.scss:142:2
> Ruleset ignored due to bad selector. _common.scss:146:2
> Ruleset ignored due to bad selector. _common.scss:151:2
> ignored due to bad selector. _common.scss:173:2
> Ruleset ignored due to bad selector. _common.scss:227:2
> Ruleset ignored due to bad selector. _common.scss:233:2
> Ruleset ignored due to bad selector. _common.scss:237:2
> Ruleset ignored due to bad selector. _common.scss:242:2
> Ruleset ignored due to bad selector. _common.scss:247:2
> Unknown property ‘-moz-osx-font-smoothing’. Declaration dropped.
> _icons.scss:16:2
> bad selector. _input.scss:26
> Unknown pseudo-class or pseudo-element ‘-ms-expand’. Ruleset ignored due
> to bad selector. _html-select.scss:31
> _icons.scss:16:2
> _icons.scss:16:2
> _icons.scss:16:2
> _icons.scss:16:2
> _icons.scss:16:2
> _icons.scss:16:2
> Error while fetching an original source: unsupported protocol for
> sourcemap request
> webpack://MapGuide/node_modules/@blueprintjs/core/src/components/tree/_tree.scss
> Source URL:
> ‫בתאריך יום ד׳, 14 ביוני 2023 ב-15:04 מאת ‪Jackie Ng‬‏ <‪
> jumpinjackie at gmail.com‬‏>:‬
>> Always look at your browser dev tools and see if a network request failed
>> or there is a javascript error on the console.
>> The init error message almost always isn't useful (it's only marginally
>> more user-friendly than a blank screen, but that's the best we can do), the
>> real error can generally be found/revealed through the devtools.
>> - Jackie
>> You wrote:
>> When using mgReact-0.14.8 on MapServer2017 windows machine, layout is not
>> showing.
>> Instead we get en error - Unexpected token '<', "
>> [image: image.png]
>> בכבוד רב,
>>  Nimrod Cnaan
>> *Please Note: I no longer create new posts or post replies to any OSGeo
>> mailing list through nabble. As a result, you most likely won't see this
>> message appear on nabble's view of any OSGeo mailing list and may only see
>> this message through mailing list archives or depending on your mailing
>> list subscription settings, through daily message digests or automated
>> notifications from the mailing lists.*
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
> בכבוד רב,
> *נמרוד כנען**   |   *גיאומינד שירותי GIS  –  פיתוח,  ייעוץ  ושירותי ענן
> ישיר: 048101268 | נייד: 0525355483 | nimrod at geomind.co.il
> נא בקרו באתר החדש שלנו http://geomind.co.il
בכבוד רב,
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230617/2b2be49f/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230617/2b2be49f/attachment.png>
