[mapguide-users] showing the filtered data on map using Search widget in fusion
    Hadis Alinia
    hadissaalinia at gmail.com
    Thu May  4 11:51:50 PDT 2023
I am using the search widget to search in a layer based on
multiple attributes, I want to show only the filtered data on the map. So I
am adding a button to do that task. I believe I need to add some scripts
and a function to Search.templ. Please let me send your sample codes for
this.
Thank you
Hadis
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230504/e856e969/attachment.htm>
