[mapguide-users] RES: RES: MGOS 4.0 and PostgreSQL
liglio.pessoal at nexxa.com.br
Mon Oct 30 06:04:37 PDT 2023
Do you know the most recent version PostgreSQL/PostGis can be used with Mapguide 3.1.2 ?
Regards,
Liglio
De: mapguide-users <mapguide-users-bounces at lists.osgeo.org> Em nome de Kajar Kuldsepp via mapguide-users
Enviada em: quinta-feira, 26 de outubro de 2023 03:23
Para: mapguide-users at lists.osgeo.org
Cc: Kajar Kuldsepp <kajar.kuldsepp at gmail.com>
Assunto: [mapguide-users] RES: MGOS 4.0 and PostgreSQL
Hi!
I tested Mapguide 4.0 and Postgresql15(Postgis 3.3.2) and I can say it's working.
Kajar
The current PostgreSQL version is 16. Support for version 11 will end in
February 2024 (AWS RDS PostgreSQL 11 must be migrated).
So, the most advanced PostgreSQL version the new Mapguide 4.0 will support is
version 12 ?
It is not possible a more recent version ? It is a FDO limitation ?
Regards,
Liglio
De: pierre.cardinal <pierre.cardi... at sympatico.ca <mailto:pierre.cardi... at sympatico.ca> >
Enviada em: terça-feira, 24 de outubro de 2023 23:49
Para: MapGuide Users Mail List <mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org> >
Cc: liglio.pess... at nexxa.com.br <mailto:liglio.pess... at nexxa.com.br>
Assunto: RE: [mapguide-users] MGOS 4.0 and PostgreSQL
The answer is
PostGIS Provider:
* Added support for PostgreSQL 12.0
* No longer joins to pg_authid when listing tables/views
* Support for curve strings and curve
<https://trac.osgeo.org/mapguide/wiki/Release/4.0.0/Beta1/Notes> https://trac.osgeo.org/mapguide/wiki/Release/4.0.0/Beta1/Notes
Regards,
Pierre
-------- Message d'origine --------
De : Liglio Cavalcante via mapguide-users <mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
< <mailto:mapguide-users at lists.osgeo.org> mailto:mapguide-users at lists.osgeo.org> >
Date : 2023-10-23 15 h 44 (GMT-05:00)
À : mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org> < <mailto:mapguide-users at lists.osgeo.org> mailto:mapguide-users at lists.osgeo.org>
Cc : liglio.pess... at nexxa.com.br <mailto:liglio.pess... at nexxa.com.br> < <mailto:liglio.pess... at nexxa.com.br> mailto:liglio.pess... at nexxa.com.br>
Objet : [mapguide-users] MGOS 4.0 and PostgreSQL
The most recent PostgreSQL/PostGis versions which are compatible to Mapguide
Server 3.1.2 are version PostgreSQL 12 and PostGis 2.5 ?
Mapguide Server 4.0 will be compatible with which versions of
PostgreSQL/PostgGis ?
Regards,
Liglio
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20231030/f1c604be/attachment-0001.htm>
