[mapguide-users] Loading Shapefile on fly using add layer manager
H A hadissaalinia at gmail.com
Tue Sep 19 09:53:11 PDT 2023
Hi
I’d like my webpage’s user to load either shapefile or tab file from their
local machine using external layer manager. I use manguide react layout so
the users are enable to add their data in GeoJson, kml and csv which is
good. But I want them to be a ale to load their shapefiles or tab files to
the map. Please advise how to proceed? And if you plan to that as
additional option in the new version of map guide layout? Or let me know
which JS code in the source files should be updated or change from our
side?
Thanks
Hadis
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230919/28d2b2b3/attachment.htm>
