[mapguide-users] Loading Shapefile on fly using add layer manager
Jackie Ng jumpinjackie at gmail.com
Thu Sep 21 03:57:31 PDT 2023
Most of what mapguide-react-layout can/cannot do is driven by the
underlying OpenLayers library we're using.
OpenLayers cannot create client-side vector layers from SHP files, so there
will not be such support in mapguide-react-layout either.
- Jackie
You wrote:
Hi
I’d like my webpage’s user to load either shapefile or tab file from their
local machine using external layer manager. I use manguide react layout so
the users are enable to add their data in GeoJson, kml and csv which is
good. But I want them to be a ale to load their shapefiles or tab files to
the map. Please advise how to proceed? And if you plan to that as
additional option in the new version of map guide layout? Or let me know
which JS code in the source files should be updated or change from our
side?
Thanks
Hadis
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230921/4ea71a07/attachment.htm>
