[mapguide-users] Loading Shapefile on fly using add layer manager
H A
hadissaalinia at gmail.com
Thu Sep 21 07:42:13 PDT 2023
Hi Jackie,
Thank you for your prompt email. Is there any other way like using leaflet,
fusion, and MapGuide rest to be able to load shapefiles?
Hadis
On Thu, Sep 21, 2023 at 6:57 AM Jackie Ng via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Most of what mapguide-react-layout can/cannot do is driven by the
> underlying OpenLayers library we're using.
> OpenLayers cannot create client-side vector layers from SHP files, so
> there will not be such support in mapguide-react-layout either.
> - Jackie
> You wrote:
> Hi
> I’d like my webpage’s user to load either shapefile or tab file from their
> local machine using external layer manager. I use manguide react layout so
> the users are enable to add their data in GeoJson, kml and csv which is
> good. But I want them to be a ale to load their shapefiles or tab files to
> the map. Please advise how to proceed? And if you plan to that as
> additional option in the new version of map guide layout? Or let me know
> which JS code in the source files should be updated or change from our
> side?
> Thanks
> Hadis
> *Please Note: I no longer create new posts or post replies to any OSGeo
> mailing list through nabble. As a result, you most likely won't see this
> message appear on nabble's view of any OSGeo mailing list and may only see
> this message through mailing list archives or depending on your mailing
> list subscription settings, through daily message digests or automated
> notifications from the mailing lists.*
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230921/c9eabef9/attachment.htm>
