[mapguide-users] Memory leak with MGOS 4 Beta 1
David Bowen
dbowenrci at gmail.com
Fri Feb 2 11:11:59 PST 2024
We've looked through the access.log but nothing stands out in the preceding
activity. There's nothing specific during the memory ramp up period that we
don't see at other times.
David
On Wed, Jan 31, 2024 at 12:01 AM Jackie Ng via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Could you correlate the time period of 11.15am - 11.45am (where the memory
> usage ramps up) with entries in your access.log and see which operations
> are involved?
> - Jackie
> You wrote:
> Hello Pierre,
> The server is running Windows 2022 Standard, we're using Apache Server and
> Oracle database. There aren't any error messages generated during the
> memory leak. We've monitored the Memory usage on this server and notice
> that memory consumption increases during the incidents (image 1). We tried
> turning on/off layers, while monitoring the memory usage, which is how we
> figured out the CLOBs issue but we haven't been able to figure out what's
> causing the remaining memory leak.
> Image 1: percent memory utilization on the server showing the increase
> until the MapGuide services become unresponsive at the peak and have to be
> restarted.
> [image: image.png]
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240202/68fa307a/attachment.htm>
