[mapguide-users] Memory leak with MGOS 4 Beta 1
Jackie Ng
jumpinjackie at gmail.com
Sat Feb 3 00:23:36 PST 2024
Ok failing that, I'll pencil in a memory leak sweep in the beta 2 dev cycle
for the King Oracle provider just like I did previously for the GDAL
provider.
https://trac.osgeo.org/fdo/ticket/1005
- Jackie
On Sat, 3 Feb 2024 at 06:12, David Bowen <dbowenrci at gmail.com> wrote:
> We've looked through the access.log but nothing stands out in the
> preceding activity. There's nothing specific during the memory ramp up
> period that we don't see at other times.
> David
> On Wed, Jan 31, 2024 at 12:01 AM Jackie Ng via mapguide-users <
> mapguide-users at lists.osgeo.org> wrote:
>> Could you correlate the time period of 11.15am - 11.45am (where the
>> memory usage ramps up) with entries in your access.log and see which
>> operations are involved?
>> - Jackie
>> You wrote:
>> Hello Pierre,
>> The server is running Windows 2022 Standard, we're using Apache Server and
>> Oracle database. There aren't any error messages generated during the
>> memory leak. We've monitored the Memory usage on this server and notice
>> that memory consumption increases during the incidents (image 1). We tried
>> turning on/off layers, while monitoring the memory usage, which is how we
>> figured out the CLOBs issue but we haven't been able to figure out what's
>> causing the remaining memory leak.
>> Image 1: percent memory utilization on the server showing the increase
>> until the MapGuide services become unresponsive at the peak and have to be
>> restarted.
>> [image: image.png]
>> mapguide-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
http://themapguyde.blogspot.com
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240203/0fb6653c/attachment.htm>
