[mapguide-users] MapGuide Site Administrator Tool
pierre.cardinal at sympatico.ca
Wed Jan 3 16:18:05 PST 2024
Hi David,
Possibly a PHP problem.
First you can try with ..\Web\Php\php.exe -v to see if your Php is running well.
Example from my installation:
D:\mgos_4.0.0.10004\Web\Php>php -v
PHP 8.1.11 (cli) (built: Sep 28 2022 11:08:01) (NTS Visual C++ 2019 x64)
Copyright (c) The PHP Group
Zend Engine v4.1.11, Copyright (c) Zend Technologies
Also with ..\Web\Php\php -i you should see the MapGuideApi module
libXML support => active
libXML Compiled Version => 2.9.12
libXML Loaded Version => 20912
libXML streams => enabled
MapGuideApi
MapGuideApi => enabled
mbstring
Multibyte Support => enabled
Multibyte string engine => libmbfl
HTTP input encoding translation => disabled
Also , if you put the file phpinfo.php that contains
<?php
phpinfo();
in the directory ..\Web\www\mapadmin then with
http://localhost:8080/mapguide/mapadmin/phpinfo.php
you should see the same kind of informations as with php -i but in a Web page.
Regards,
Pierre
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de David Bowen via mapguide-users
Envoyé : 3 janvier 2024 07:50
À : MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Cc : David Bowen <dbowenrci at gmail.com>
Objet : [mapguide-users] MapGuide Site Administrator Tool
I reinstalled MapGuide 4.0 Beta 1 on one of our servers and now I'm unable to log into the Site Administrator Tool using the credentials Administrator and admin. I get the error " Authentication failed. Please enter a valid username and password". I'm able to use these credentials on different servers without issue.
Has anyone encountered this issue? Any suggestions on how to resolve it?
Thanks,
David
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240103/1591d99b/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240103/1591d99b/attachment.png>
