[mapguide-users] MapGuide Site Administrator Tool
David Bowen dbowenrci at gmail.com
Thu Jan 4 07:11:04 PST 2024
Thanks Pierre. I ended up having to reinstall MGOS 4 Beta 1, to address
other issues, which seems to have fixed the problem.
On Wed, Jan 3, 2024 at 7:18 PM <pierre.cardinal at sympatico.ca> wrote:
> Hi David,
> Possibly a PHP problem.
> First you can try with ..\Web\Php\php.exe -v to see if your Php is running
> well.
> Example from my installation:
> D:\mgos_4.0.0.10004\Web\Php>php -v
> PHP 8.1.11 (cli) (built: Sep 28 2022 11:08:01) (NTS Visual C++ 2019 x64)
> Copyright (c) The PHP Group
> Zend Engine v4.1.11, Copyright (c) Zend Technologies
> Also with ..\Web\Php\php -i you should see the MapGuideApi module
> *libXML support => active*
> *libXML Compiled Version => 2.9.12*
> *libXML Loaded Version => 20912*
> *libXML streams => enabled*
> *MapGuideApi*
> *MapGuideApi => enabled*
> *mbstring*
> *Multibyte Support => enabled*
> *Multibyte string engine => libmbfl*
> *HTTP input encoding translation => disabled*
> Also , if you put the file phpinfo.php that contains
> <?php
> phpinfo();
> in the directory ..\Web\www\mapadmin then with
> http://localhost:8080/mapguide/mapadmin/phpinfo.php
> you should see the same kind of informations as with php -i but in a Web
> page.
> Regards,
> Pierre
> *De :* mapguide-users <mapguide-users-bounces at lists.osgeo.org> *De la
> part de* David Bowen via mapguide-users
> *Envoyé :* 3 janvier 2024 07:50
> *À :* MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> *Cc :* David Bowen <dbowenrci at gmail.com>
> *Objet :* [mapguide-users] MapGuide Site Administrator Tool
> I reinstalled MapGuide 4.0 Beta 1 on one of our servers and now I'm unable
> to log into the Site Administrator Tool using the credentials Administrator
> and admin. I get the error " Authentication failed. Please enter a valid
> username and password". I'm able to use these credentials on different
> servers without issue.
> Has anyone encountered this issue? Any suggestions on how to resolve it?
> Thanks,
> David
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240104/c6609010/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240104/c6609010/attachment.png>
