[mapguide-users] Unable to save MapGuide Site Admin tool
pierre.cardinal at sympatico.ca
Wed Jan 10 10:57:11 PST 2024
Hi David,
Effectively there is a problem with Apache and PHP (IIS is OK)
But to modify your settings, add the following lines to the file serverconfig.ini
[AccessLogProperties]
# A C C E S S L O G
# Property Name Description
# Enabled 0 = log disabled, 1 = log enabled
# Filename Name of the log file
# Parameters Log parameters
Parameters = CLIENT, CLIENTIP, USER, OPID
Filename = Access%d.log
Enabled = 1
Note :
Filename = Access%d.log for DAY
Filename = Access%m.log for MONTH
Filename = Access%y.log for YEAR
Filename = Access.log for NONE
Regards,
Pierre
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de David Bowen via mapguide-users
Envoyé : 10 janvier 2024 09:30
À : MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Cc : David Bowen <dbowenrci at gmail.com>
Objet : [mapguide-users] Unable to save MapGuide Site Admin tool
I'm attempting to update settings in the Site Administrator tool but when I click on Save, a blank page is returned. When I click on the go back button, none of the updated settings are shown.
Has anyone encountered this? I know you can update the serverconfig.ini file but I'm trying to update how often the logs are archived and there doesn't appear to be an option for it in the serverconfig.ini file.
Thanks,
David
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240110/fd35432c/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240110/fd35432c/attachment.png>
