[mapguide-users] Authentification doesn't work
pierre.cardinal
pierre.cardinal at sympatico.ca
Tue Jan 16 07:03:14 PST 2024
Hi François, This problem is in general caused by the fact that your MapGuide server is not running. Check your services for MapGuide server or try to start you server with the following command ".. /server/bin/mgserver.exe" in the directory where you installed the MapGuide application. Salutations, PierreEnvoyé de mon appareil Samsung de Bell via le réseau le plus vaste au pays.
-------- Message d'origine --------De : Francois Regnard via mapguide-users <mapguide-users at lists.osgeo.org> Date : 24-01-16 02 h 13 (GMT-05:00) À : mapguide-users at lists.osgeo.org Cc : frdl at free.fr Objet : [mapguide-users] Authentification doesn't work Hi,I recently tried to install mapguide 4.0.0.1 on a Professionnal Windows 10 for my company. Up until then, we used a linux server for that, but I had to fetch the data on the windows server for our users to have the same experience as they're used to. However, logging in, even as Administrator, doesn't work. It gives back an error "Authentification failed. Please enter a valid username and password."Just to be sure, I uninstalled everything, rebooted, reinstalled Mapguide leaving every default option (ip adress, port, packages...), and I still get the same authentication error. Could that be related to ports or something like that ?Thanks,Francois _______________________________________________mapguide-users mailing listmapguide-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240116/10fee285/attachment.htm>
