[mapguide-users] IronPython - automate Maestro
Bart Oostdam
bart at giskit.nl
Thu Jul 25 04:59:34 PDT 2024
Hello Jackie,
Very grateful for your elaborate answer.
I did look at the XML structure and I am quite familiar with reading it and understanding how it is structured.
I just did not connect the dots thus far.
I am quite used to having a ‘command-reference’ guide.
Maybe that made me spoiled. 😊
I will give it another go and see what I can accomplish.
Thank you very much so far and thank you for the corrected code sample.
It will be very helpful I am sure.
Met vriendelijke groet,
GISkit BV
Bart Oostdam
Van: mapguide-users <mapguide-users-bounces at lists.osgeo.org> Namens Jackie Ng via mapguide-users
Verzonden: donderdag 25 juli 2024 13:46
Aan: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
CC: Jackie Ng <jumpinjackie at gmail.com>
Onderwerp: Re: [mapguide-users] IronPython - automate Maestro
You really have to be familiar with the XML structure of the resources you are working with. The objects you are interacting with on the console are objects that have near 1:1 structure with their respective XML schema definition.
The bulk of the Maestro API is C# classes auto-generated from the .xsd documents that ship with MapGuide. These .xsd files describe the shape of all the resources (and all the versions of these resources) you can work with in MapGuide. Because these .xsd documents exist in multiple versions, we use C# interfaces to provide commonality across these different auto-generated classes and when working with resources in Maestro API, you're working against these interfaces and never have to deal with the underlying auto-generated classes.
I'm sorry if the API documentation is not that helpful or barebones around these classes/interfaces because practically speaking at the moment it is simpler to just look at the underlying .xsd documents to understand the XML structure of a specific resource type rather than painstakingly repeat all of this documentation in our common wrapping interfaces.
In the case of Layer Definitions, you should refer to the respective LayerDefinition.xsd to understand the structure of a Layer Definition document. These schema files are in the Server/Schema folder of your MapGuide install and are also included in the Schemas directory of your Maestro installation. If you're unable to read/understand these .xsd schema files then I can't really help you there.
Either way, I'll give you a cliff-notes version of the Layer Definition structure:
A Layer Definition has:
- A sub element that indicates if this is a vector, raster or DWF-based drawing layer
- Because we're dealing with a vector layer, it has 1:n vector scale ranges
- Each vector scale range has *zero or one* of:
- A point style
- With 1:n point rules
- A line style
- With 1:n line rules
- An area (polygon) style
- With 1:n area rules
- A composite style (if using advanced stylization)
- With 1:n composite rules
So to then revisit your original problem: Why is there no GetPointStyleAt() function?
Because there is indeed no such function. There's only one point style: The .PointStyle property.
Same thing for line/area/composite styles.
We only provide GetXXXAt() and AddXXX() functions for elements that can exist 1 or more times. Point styles do not qualify. Therefore they only exist as properties to set directly.
Therefore your code should've been this:
if vectorScaleRange.PointStyle is None:
pointStyle = ldf.CreateDefaultPointStyle()
#Add the new pointStyle to the vectorScaleRange
vectorScaleRange.PointStyle = pointStyle
else:
print "There already is a pointStyle"
I would think and hope that as you were typing your original code out in the IronPython console, that the autocomplete did not provide any suggestions for GetPointStyleAt after you hit dot after vectorScaleRange. That is because the autocomplete was telling the truth: There is no such function on the vectorScaleRange object.
- Jackie
You wrote:
Sorry to bother you again.
Trying:
if vectorScaleRange.GetPointStyleAt(0) is None:
vectorScaleRange.PointStyle.AddPointStyle(pointStyle)
else:
Apparently there is no GetPointStyle() or GetPointStyle
Here is where I cannot seem to grasp the logic of things.
Is there documentation about all getters and setters ?
I searched the API documentation for PointStyle and there is a decscription, however:
I franly do not understand how to use the API documentation and apply it in the context of IronPython.
(There is not much to go on for a beginner on it seems)
GISkit BV
Bart Oostdam
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240725/20b22ce3/attachment.htm>
