[mapguide-users] WMS layer name problem
Jackie Ng jumpinjackie at gmail.com
Thu Sep 5 06:24:54 PDT 2024
An update on the example layers.
I could not reproduce the problems you described. I set up a WMS feature
source in Maestro (git master) with a slimmed down configuration doc
focused only on the layers you specified and I was able to create and
preview all the layers specified.
To see for yourself, I've uploaded a package containing this WMS feature
source and all the layers you mentioned here:
https://download.osgeo.org/mapguide/testing/data/WMS.mgp
This package loads into Library://WMS/ so make sure nothing else is there
already or it may get overwritten by this package when loaded.
So as far as I'm concerned, the displaying of these WMS layers is fine on
any viewer as MapGuide layers using the WMS FDO Provider. However if you
desire GetFeatureInfo-based interaction, then my mapguide-react-layout
viewer recommendation still stands.
- Jackie
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240905/42030e1e/attachment.htm>
