[mapguide-users] WMS layer name problem
Jackie Ng
jumpinjackie at gmail.com
Thu Sep 12 06:22:31 PDT 2024
I tried the package you provided and it loads just fine for me, but the
layers within point to a non-existent feature source.
I re-tried loading the package I provided a link to in many different ways
(via Maestro and the Site Administrator tool) and both methods produce a
Feature Source that has no errors.
I don't know what else to say: The package I linked to works for me. I
cannot see the problems you are facing.
- Jackie
You wrote:
Hi Jackie,
Thank you for all the information and the test that you did.
There is something strange: i load your package but, during the test
connection appears the following error:
FDO Connection Status:
The remote server returned an error: (559) MgFdoException.: The
custom error module does not recognize this error.
I compared the 2 config file and two main difference are the following:
- MM config: <xs:maxLength value="0" /> / JK config: <xs:maxLength
value="256" />
- where you put x20 the maestro by me put x2e
But in both case the connection doesn't work, or by loading your package
or by creating the feature source new by me.
Do you have some idea?
Here a link to my actual package
https://www.swisstransfer.com/d/0500602d-5285-4071-b49e-b66c0bf74137
Do you have some idea about this issue
Thank you
*MAURIZIO MASELLI*
Geografo dipl. Bsc UZH, Ingegnere geologo dipl. MSc ETHZ
Caposettore Geoinformazione
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240912/9388f27f/attachment.htm>
