[mapguide-users] Trouble with layer using Postgresql data
Scott Hameister flipper at buoyshark.com
Fri Apr 11 05:46:24 PDT 2025
Happens with SQL as well. Also happens with empty tables (electric outages)
if a reboot occurs, can also get messed up by bad views. It seems a schema
snapshot occurs at startup, or refreshing of data source. Makes some sense
since it would be a big time waste to check schema at every redraw
On Fri, Apr 11, 2025, 7:25 AM Kajar Kuldsepp via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Hi!
> There have been issue for a years with layers based the Postgresql table
> data.
> No matter which Postgresql version or mapguide version I have used, for me
> it have been always issue.
> Problem: layer becomes invisible, when Postgresql schema structure will
> change(new table have created). For a sample I have table A under public
> schema, which is source of Mapguide layer. Now I create table B in public
> schema and this will make layer consuming table A data invisible on the
> map.
> I use built in Postgresql provider to create feature source.
> I found workaround for that issue: when layer become invisible I have to
> use Maestro and open that Postgresql feature source and just save it again
> and this will fix the issue.
> Does anyone else experience similar behavior and how to fix it?
> Kajar
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250411/f4748380/attachment.htm>
