[mapguide-users] Trouble with layer using Postgresql data
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Fri Apr 11 07:11:06 PDT 2025
The Caching of the database connection is the issue.
Workarounds:
1. Restart MapGuide Server
2.Redifine Data Connection and re-save
3. Step 2 plus re-point the layer back to the Data Connection to see
changes to the database.
On Fri, Apr 11, 2025 at 8:46 AM Scott Hameister via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Happens with SQL as well. Also happens with empty tables (electric
> outages) if a reboot occurs, can also get messed up by bad views. It seems
> a schema snapshot occurs at startup, or refreshing of data source. Makes
> some sense since it would be a big time waste to check schema at every
> redraw
> On Fri, Apr 11, 2025, 7:25 AM Kajar Kuldsepp via mapguide-users <
>> Hi!
>> There have been issue for a years with layers based the Postgresql table
>> data.
>> No matter which Postgresql version or mapguide version I have used, for
>> me it have been always issue.
>> Problem: layer becomes invisible, when Postgresql schema structure will
>> change(new table have created). For a sample I have table A under public
>> schema, which is source of Mapguide layer. Now I create table B in public
>> schema and this will make layer consuming table A data invisible on the
>> map.
>> I use built in Postgresql provider to create feature source.
>> I found workaround for that issue: when layer become invisible I have to
>> use Maestro and open that Postgresql feature source and just save it again
>> and this will fix the issue.
>> Does anyone else experience similar behavior and how to fix it?
>> Kajar
>> mapguide-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250411/b109cd55/attachment.htm>
