[mapguide-users] Trouble with layer using Postgresql data
    Jackie Ng
    jumpinjackie at gmail.com
    Fri Apr 11 22:21:36 PDT 2025
Hi Kajar,
Yes this is kind of expected behavior. MapGuide will cache schema/class
structures to avoid repeated lookups for this info on every render. However
if you change the db structure from underneath MapGuide (like through an
external db admin tool which I assume is what you are doing), how is
MapGuide supposed to know about that if you didn't make the structural
changes through only the APIs provided by MapGuide?
Saving any feature source will auto-purge all cached schema/class
structures associated with that feature source. So your provided workaround
is generally the way to go.
- Jackie
You wrote:
Hi!
There have been issue for a years with layers based the Postgresql table
data.
No matter which Postgresql version or mapguide version I have used, for me
it have been always issue.
Problem: layer becomes invisible, when Postgresql schema structure will
change(new table have created). For a sample I have table A under public
schema, which is source of Mapguide layer. Now I create table B in public
schema and this will make layer consuming table A data invisible on the
map.
I use built in Postgresql provider to create feature source.
I found workaround for that issue: when layer become invisible I have to
use Maestro and open that Postgresql feature source and just save it again
and this will fix the issue.
Does anyone else experience similar behavior and how to fix it?
Kajar
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250412/b10c5be4/attachment.htm>
