[mapguide-users] Trouble with layer using Postgresql data
Scott Hameister flipper at buoyshark.com
Fri Apr 11 22:37:06 PDT 2025
My biggest issue, is it seems to get messed up even with SQL if the
database is empty after reboot, or reset. Think electric outages, normally
empty.
On Sat, Apr 12, 2025, 12:21 AM Jackie Ng via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Hi Kajar,
> Yes this is kind of expected behavior. MapGuide will cache schema/class
> structures to avoid repeated lookups for this info on every render. However
> if you change the db structure from underneath MapGuide (like through an
> external db admin tool which I assume is what you are doing), how is
> MapGuide supposed to know about that if you didn't make the structural
> changes through only the APIs provided by MapGuide?
> Saving any feature source will auto-purge all cached schema/class
> structures associated with that feature source. So your provided workaround
> is generally the way to go.
> - Jackie
> You wrote:
> Hi!
> There have been issue for a years with layers based the Postgresql table
> data.
> No matter which Postgresql version or mapguide version I have used, for me
> it have been always issue.
> Problem: layer becomes invisible, when Postgresql schema structure will
> change(new table have created). For a sample I have table A under public
> schema, which is source of Mapguide layer. Now I create table B in public
> schema and this will make layer consuming table A data invisible on the
> map.
> I use built in Postgresql provider to create feature source.
> I found workaround for that issue: when layer become invisible I have to
> use Maestro and open that Postgresql feature source and just save it again
> and this will fix the issue.
> Does anyone else experience similar behavior and how to fix it?
> Kajar
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250412/506a426c/attachment.htm>
