[mapguide-users] MapGuide Maestro 6.0m13 and mapguide-react-layout 0.14.10 released
Nimrod Cnaan
nimcnaan at gmail.com
Mon Feb 17 23:33:44 PST 2025
[image: image.png]
בתאריך שבת, 15 בפבר׳ 2025 ב-3:11 מאת Jackie Ng via mapguide-users <
mapguide-users at lists.osgeo.org>:
> This is not helpful. I do not see any relation between the
> unexpected token `<` and this error.
> The mapInit property is an AJAX viewer API property that custom task pane
> content can test to see if the map viewer is ready to start using their
> other APIs. This error suggests that you must have a custom InvokeURL
> command that has some javascript that calls this property without testing
> that the call chain is already not null/undefined (ie.
> Caling parent.parent.mapInit without testing that parent.parent is not
> null/undefined first)
> Again I am just speculating because I have not been given enough
> information to work with.
> Can you switch over to use viewer-debug.js (instead of viewer.js) and
> provide screenshots of the viewer and relevant parts of the developer tools
> where the error is happening?
> - Jackie
> You wrote:
> this is the Error we get - Uncaught TypeError: Cannot read properties of
> undefined (reading 'mapInit')
> at About:486:42
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
בכבוד רב,
*נמרוד כנען** | *גיאומינד שירותי GIS – פיתוח, ייעוץ ושירותי ענן
ישיר: 048101268 | נייד: 0525355483 | nimrod at geomind.co.il
נא בקרו באתר החדש שלנו http://geomind.co.il
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250218/13f6704f/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250218/13f6704f/attachment.png>
